2 Replies Latest reply on Feb 9, 2009 12:37 AM by Rajeev Kumar MIL
    Inject XSLT in IDML via plugin
      I wonder if it is possible to manipulate the IDML code from an InDesign plugin? Our idea is to add XSLT to an IDML document and transform that document to an IDML document and generate PDF:s from it. Is that possible?
        • 1. Re: Inject XSLT in IDML via plugin
          I'm not sure what you mean by "manipulate the IDML code." I've done something like what you've described, but completely outside of InDesign. Keep in mind an IDML file is just a collection of XML files so making templates that can transform into IDML content is quite possible.
          And, when you say "PDF:s" do you mean "PDFs"? Or is "PDF:s" something I'm just not familiar with. Please provide a pointer. If it's just PDFs, then you'll need a running instance of InDesign or InDesign Server to turn the IDML file into a PDF.
          Heath Lynn
          • 2. Re: Inject XSLT in IDML via plugin
            Rajeev Kumar MIL Level 1
            Hi Heath,
            I have one XML file and I want to transform it using XSL, so that XML file get imported and paginated. Then I can make PDF from that file.
            If you have done this type of activity then please help me on this.
            Rajeev
