1 Reply Latest reply on Jan 14, 2009 12:58 PM by (thomas_bro)
    edit inDesign templates online
      Hi, does anyone know a solution to edit an indesign template online?
      Here is the situation:
      I have a template of a letter, I define a couple of fields to be variable (let's say title, name, signature name)
      I want to build a website to view the template, edit the fields, preview the result, and export as pdf
      Do you know if there is any solution available to do that?
      thanks,
      Stan
        • 1. Re: edit inDesign templates online
          Level 1
          What you are looking for can be found at www.pectora.com. They have an online webeditor that can do the job. However it is part of a high-end solution and could turn out to be pricey :-)
          Pectora is also part of a solution called IMMIX. It involves a CMS system called Sitecore and communicates directly with InDesign/InDesign Server.
          keep smiling
          Thomas
