0 Replies Latest reply on Feb 26, 2009 1:13 PM by (JIm_C_Thompson)
    Problem adding image to document
      I am adding a Rectangle to a document and placing a JPEG file. The result opens in InDesign and shows a rectangle that is filled with dark grey. The links palette shows the jpeg file and notes it to be current. If I re-link the graphic it shows correctly. What do I need to do so the image shows after the doc is created?
      private void IndCreateFrame(double xc, double yc, double w, double d, String Layername, String frameType, long frameColCount, String imagePath)
      Rectangle newFrame = null;
      ObjectStyle myObjectStyle = null;
      VariableType strokeType = new VariableType();
      strokeType.asString("Solid");
      Unit strokeWeight = new Unit();
      strokeWeight.asDouble(2.5);
      try
      int oldH = myApp.getViewPreferences().getHorizontalMeasurementUnits();
      int oldV = myApp.getViewPreferences().getVerticalMeasurementUnits();
      myApp.getViewPreferences().setHorizontalMeasurementUnits(com.adobe.ids.enums.kMeasurement UnitsPoints.value);
      myApp.getViewPreferences().setVerticalMeasurementUnits(com.adobe.ids.enums.kMeasurementUn itsPoints.value);
      PDFPlacePreference myPdfPrefs = myApp.getPDFPlacePreferences();
      myPdfPrefs.setPDFCrop(com.adobe.ids.enums.kPDFCropCropMedia.value);
      newFrame = myPage.addRectangle(OptArg.noLayer(),
      OptArg.makeLocationOptionsEnum(kLocationOptionsUnknown.value),
      OptArg.noVariableType());
      newFrame.setContentType(com.adobe.ids.enums.kContentTypeGraphicType.value);
      System.out.println("Place file " + imagePath);
      VariableType[] placedItems = newFrame.place(imagePath);
      Graphic[] myGraphics = newFrame.getAllChildGraphics();
      System.err.println("GRAPHIC COUNT - " + myGraphics.length);
      System.out.println("Set frame bounds to " + yc + ", " + xc + ", " + (yc + d) + ", " + (xc + w));
      newFrame.setGeometricBounds(UnitUtils.createDouble(new double[]{
      yc, xc, yc + d, xc + w}));
      boolean needStyle = true;
      try
      myObjectStyle = myDoc.getNamedChildObjectStyle("GraphicFrame");
      if (myObjectStyle != null) needStyle = false;
      catch (IdsException idEx)
      System.err.println("We got an exception looking for the GraphicFrame Object Style.");
      if (needStyle == true)
      myObjectStyle = myDoc.addObjectStyle();
      myObjectStyle.setName("GraphicFrame");
      System.err.println("Current enable stroke value is " + myObjectStyle.getEnableStroke());
      myObjectStyle.setEnableStroke(true);
      myObjectStyle.setStrokeWeight(strokeWeight);
      myObjectStyle.setStrokeType(strokeType);
      try
      newFrame.applyObjectStyle(myObjectStyle, new OptBoolean(false, false), new OptBoolean(false, false));
      catch (Exception ex)
      ex.printStackTrace();
      newFrame.fit(kFitOptionsContentToFrame.value);
      myApp.getViewPreferences().setHorizontalMeasurementUnits(oldH); myApp.getViewPreferences().setVerticalMeasurementUnits(oldV);
