2 Replies Latest reply on Sep 19, 2008 1:21 AM by bART2007
    TextFrames in InDesign CS3
      Is it possible in a InDesign document (.indd) to setup TextFrames 'that moves proportionally' (with exactly the same space in between) when using 'Fit Frame To Content' on one or multiple TextFrames - or can this only be achieved with scripting?
      Can TextFrames with multiple columns be re-sized when the amount of content changes? I have noticed that textFrame.fit(FitOptions.FRAME_TO_CONTENT) doesn't re-size the TextFrame if it has more then one column.
      Thanks in advance
        • 1. Re: TextFrames in InDesign CS3
          its working in my case....
          I have another problem....
          I want to fit my image in right/left side but its not working....
          myTextFrame.frameFittingOptions.fittingAlignment = AnchorPoint.TOP_RIGHT_ANCHOR;
          • 2. Re: TextFrames in InDesign CS3
            bART2007
            I'm running into the same problem. I have a TextFrame with content that is different depending on the situation. So after I set the TextFrame content, I want to fit the frame to the content but only horizontally.
            It's easy to do in the InDesign UI (double click on a left or right side guide of the frame).
            Any suggestions?
            Thanks in advance.
