3 Replies Latest reply on Jun 20, 2010 7:36 PM by Vijay Sahu
    using indesign files in asp.net
      hi friends,
      I am building an application in asp.net in which my task is to create a pdf file by using the Adobe Indesign CS2 in asp.net.
      I am using the code which is found from the net but on running this is given an error That:
      "System.UnauthorizedAccessException: Access is denied."
      now tell me about this error and what i have to do to achieve this task. this is really urgent one
      atleast reply if u don't know the answer also please.......
      Here's my code::
      Imports System
      Imports System.Data
      Imports System.Configuration
      Imports System.Web
      Imports System.Web.Security
      Imports System.Web.UI
      Imports System.Web.UI.WebControls
      ' Imports System.Web.UI.WebControls.WebParts
      Imports System.Web.UI.HtmlControls
      Imports InDesign
      Public Class _Default
      Inherits System.Web.UI.Page
      Protected Sub Page_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
      Dim cstrInddFile As String = Server.MapPath("~/Archieve/yourstory_backcover1.indd")
      Dim cstrXMLFile As String = Server.MapPath("~/Archieve/xml1.xml")
      Dim cstrOutputFile As String = Server.MapPath("~/Archieve/out.pdf")
      Dim indAppType As Type = Type.GetTypeFromProgID("InDesign.Application")
      Dim objInDesign As InDesign.Application = DirectCast(Activator.CreateInstance(indAppType, True), InDesign.Application)
      Dim objDoc As InDesign.Document = DirectCast(objInDesign.Open(cstrInddFile, False), InDesign.Document)
      objDoc.ImportXML(cstrXMLFile)
      Dim objPreset As InDesign.PDFExportPreset=DirectCast(objInDesign.PDFExportPresets.LastItem(),InDesign.PDFE xportPreset)
      objDoc.Export(idExportFormat.idPDFType, cstrOutputFile, False, objInDesign.PDFExportPresets("Press"))
      End Sub
      End Class
