5 Replies Latest reply on Dec 4, 2008 10:09 AM by (kotaro)
    InDesign Server command-line flags
      How can I get command-line flags list of InDesign Server?
      Actually the situation is testclient doesn't work.
      I installed InDesign Server and SDK.
      I run InDesignServer.com then I use something like this "testclient -server t.js".
      Server and client runs on same comp.
      As result I have this exception:
      SOAP FAULT: SOAP-ENV:Client
      "Unknown error"
      Detail: TCP connect failed in tcp_connect()
      in SDK indesign-server-test-client.pdf I found:
      "Using InDesign Server
      In order to use the test client, you must have a machine that has InDesign Server installed and
      running properly, as the test client will communicate with the InDesign Server application.
      For instructions on running and terminating InDesign Server, including command-line flags,
      please refer to the InDesign Server Installation and Configuration Guide."
      Any suggestion?
        • 1. Re: InDesign Server command-line flags
          We should implement a mechanism to get the command line options for InDesign Server. There's some reasons why we didn't but we could probably get around them. They should be documented in the SDK. Let me know if you can't find them.
          testclient does not have to run on the same machine. The client and the server can be on different machines. You need to use the -host option in testclient to specify the SOAP port that the server is listening on. If it is on the same machine you would do something like this:
          testclient -host localhost:5000 t.js
          The -server option to testclient indicates to testclient that the script exists on the server's file system. An the path you specify of the script is a path on the server's file system. If you don't specify -server, then testclient assumes the script is on the client. It then reads the script and sends the script text over the wire, rather than a pathname.
          Michael-
          • 2. Re: InDesign Server command-line flags
            Level 1
            Thanks Michael
            • 3. Re: InDesign Server command-line flags
              I figured out, accidentally, how to get the command line options.
              Just try to start a second instance of indesign without specifying a unique configuration name. When you do this it errors out and gives you the command line options which are:
              usage: InDesignServer [ options ]
              options: -console -port number -configuration name -iorfile path -pluginpath partialpath -vcusersfile
              _ Sean
              • 4. Re: InDesign Server command-line flags
                Level 1
                Hi folks,
                the easiest way is to read the documentation. It's called "Intro to InDesign CS3 Server.pdf" (serversdk/docs/guides or IDS/documentation/English) and on page 8 you will find the following:
                InDesign Server arguments
                The InDesign Server command-line arguments enable you to configure various aspects of
                InDesign Server. The command line has the following syntax; the options are described in
                Table 2:
                InDesignServer [ -port number ] [ -configuration name ]
                [ -iorfile filepath ] [ -pluginpath folderpath ]
                [ -[no]errorlist ] [ -LogToApplicationEventLog ] [ -[no]previews ]
                [ -timeout timeoutvalue ] [ -sleep sleepvalue ]
                [ -vcusersfile filepath ] [ -console ] [ -help ]
                Tino
                • 5. Re: InDesign Server command-line flags
                  Level 1
                  Hello guys! It is possible to get values from command line.
                  Let's see this example:
                  testclient -host localhost:6666 myscript.jsx "x=123456"
                  To access "x" inside myscript.jsx just type:
                  var my_x = app.scriptArgs.getValue("x");
                  Good Luck :-)
                  http://www.kikuchi.adm.br
