• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Missing required system fonts or cmap files
New Here ,
Dec 17, 2005 Dec 17, 2005
Hello,
I installed (and uninstalled and reinstalled over and over) InDesign CS2 today (via the full Creative Suite 2 installer), and every time I try to launch it, I get the dreaded "missing required system fonts or cmap files. please reinstall" dialog.
I have read and tried http://www.adobe.com/support/techdocs/324343.html. I have manually copied in the ZX______.PFM and ZY______.PFM files. I have deleted the AdobeFnt*.lst files, and reinstalled.
Nothing seems to work.
Could someone assist with a solution?
Regards,
Allan
Views
48.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
replies 101 Replies 101
New Here ,
Jan 30, 2006 Jan 30, 2006
Hi Alan,
I'm experiencing the exact same difficulty you experienced when attempting to launch InDesign and I have tried the same solutions but to no avail. Your message is dated December 17,2005. I was wondering if you have resolved the issue since then and if so what is the solution?
Thanks in advance.
Gerry
Votes
Translate
Translate
Report
Report
New Here ,
Feb 06, 2006 Feb 06, 2006
Dear Allan and Gerry,
I do have the same problem with the official trial version of Adobe InDesign and I'm looking hard for a solution, but I can not find one.
Did one of you solve the problem?? If yes, what is the (final)solution???
Thanks in advance...
Kees Huigen
Votes
Translate
Translate
Report
Report
New Here ,
Feb 08, 2006 Feb 08, 2006
I have the full version of CS, and I'm getting the same errors. HELP! Is there a patch fix for this?
Votes
Translate
Translate
Report
Report
New Here ,
Dear Mitch,
Which version of Apple QuickTime you've installed on your computer?
Viewer .. Pro 6.. or 7?
Please, let me know! Thanks!
Kees Huigen
Votes
Translate
Translate
Report
Report
New Here ,
Feb 09, 2006 Feb 09, 2006
I have had this problem too on a Windows XP Home machine.
The fix that we found was to log in as the administrator and set all the subdirectories of "Documents and Settings/All Users" to full permissions for all of the machine's users. After opening the permissions, re-run the install and all of the necessary files should be placed properly.
If you need more details, let me know.
John
Votes
Translate
Translate
Report
Report
New Here ,
Kees Huigen - I have quicktime 7.
John - I am an Admin on the machien as well, so I'd think the files should have installed properly??
Votes
Translate
Translate
Report
Report
New Here ,
I found the following solution:
- remove manually : Program Files/Common Files/Adobe/Fonts/Reqrd/Base
- re-install Adobe InDesign (Program can be launched and works!)
- get update (version 4.0.2)
- and finally.... Go to work!!
Please let me know if this solution was helpfull, thanks!!
Kees Huigen
Votes
Translate
Translate
Report
Report
New Here ,
I've tried this fix (removing the Base directory and reinstalling) and no luck. I'll try the update though, not sure if I have that..
Votes
Translate
Translate
Report
Report
New Here ,
When you say "reinstall", do you mean to reinstall over the previous, or completely uninstall then reinstall.
Unless I uninstall first, it only allows me to run the Repair, which doesn't restore the Base directory or fix the issue.
If I uninstall/reinstall, I end up in the same place.
I've manually copied the missing ZX and ZY font files into the Base directory, but that doesn't fix either.
Nor does running the update.
Votes
Translate
Translate
Report
Report
New Here ,
Can anyone tell me what CMAP files I need? Maybe those are the issue, not fonts...?
Votes
Translate
Translate
Report
Report
New Here ,
Feb 10, 2006 Feb 10, 2006
So I've tried all of the suggested fixes, and nothing works.
Votes
Translate
Translate
Report
Report
New Here ,
Mitch,
I meant: remove the Program Files/ ... /Base
Reinstall without uninstalling first. : the .../Base will not be replaced, wich caused me no problems at all (I've used InDesign almost the entire day and I did not experience any failures so far.
What also might be helpfull is the following: uninstall QuickTime and reinstall it after you've reinstalled InDesign (be sure that QuickTime is the default viewer!!!)
If this will not help I'll search for the CMAP files!
I've also copied all the files to the CMAP over and over again, but that did not bring me any luck!
For now Good Luck!!
Kees Huigen
Votes
Translate
Translate
Report
Report
New Here ,
Feb 13, 2006 Feb 13, 2006
Is Adobe doing anything about this? I've found this same complaint on dozens of other boards, with the same install error. You'd think they'd release a patch to address it.
Votes
Translate
Translate
Report
Report
Community Expert ,
In my experience, the Missing CMap error almost always happens when you try to remove all the fonts from the Adobe Creative Suite private font location. In Windows that's: Program Files > Common Files > Adobe > Fonts.
There is a Reqd folder which cannot be removed or InDesign (and possibly other CS2 applications) will complain with that error message.
Votes
Translate
Translate
Report
Report
New Here ,
Ok I've reinstalled again. The folder structure is intact. I found on another forum a suggestion to make sure the Adobe SAM MM file is in the Base folder as well. Any idea what file this is?
Votes
Translate
Translate
Report
Report
New Here ,
Removing Quicktime did not help, btw.
Votes
Translate
Translate
Report
Report
New Here ,
Hmm, nevermind my other post. They were talking about the Adobe SanMM font files... (typo). I've made sure those are all in the correct location.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 02, 2006 Mar 02, 2006
If you have the luxury of having InDesign CS2 installed on multiple machines, you can copy the
"C:\Program Files\Common Files\Adobe\Fonts"
folder from a working computer to the same location on the one producing the error message. Copying just the Base folder under Fonts didn't work, but the entire Fonts folder did the trick in my case.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 30, 2006 Mar 30, 2006
evil, i have the same problem
Votes
Translate
Translate
Report
Report
New Here ,
Mar 31, 2006 Mar 31, 2006
I have this very problem too :(
Is it possible to contact Adobe directly about this? Their "fixes" don't work, and I'm left here with a piece of software costing hundreds of pounds which won't even open. As you may imagine, I'm not best pleased...
Tony.
PS Thank you nonetheless to all those kind folks who have offered their assistance thus far.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 07, 2006 Apr 07, 2006
I CANNOT fix this issue. No matter how many times I uninstall, install, reinstall, in any order, I just can't get it done. I've even tried, not sure why this would help, but have done the same in combination with quicktime. The solutions they offer just aren't working for me, and I'd appreciate any help.
Someone offered the idea of copying from another PC the missing files. I don't have this installed on another PC. Is there a way I could download the files separately?
Votes
Translate
Translate
Report
Report
New Here ,
Apr 19, 2006 Apr 19, 2006
I just opened my NEW CS2 prem and installed it and cannot open ID...I am getting the same...
I called adobe for help! did not get problem resolved!!!!! THANKS! not!
You would think for $1200.00 it would work.... typical adobe
Votes
Translate
Translate
Report
Report
New Here ,
The only way I was able to fix my missing files error was to request the files from another user on iRC. I HAVE the missing Cmap files that caused this issue for me.
These files go in the following folder:
C:\Program Files\Common Files\Adobe\Fonts\Reqrd\CMaps
The following files that should be in there are:
78-EUC-H
78-EUC-V
78-H
78-RKSJ-H
78-RKSJ-V
78-V
78ms-RKSJ-H
78ms-RKSJ-V
83pv-RKSJ-H
90ms-RKSJ-H
90ms-RKSJ-V
90msp-RKSJ-H
90msp-RKSJ-V
90pv-RKSJ-H
90pv-RKSJ-V
Add-H
Add-RKSJ-H
Add-RKSJ-V
Add-V
Adobe-CNS1-0
Adobe-CNS1-1
Adobe-CNS1-2
Adobe-CNS1-3
Adobe-CNS1-4
Adobe-GB1-0
Adobe-GB1-1
Adobe-GB1-2
Adobe-GB1-3
Adobe-GB1-4
Adobe-Japan1-0
Adobe-Japan1-1
Adobe-Japan1-2
Adobe-Japan1-3
Adobe-Japan1-4
Adobe-Japan1-5
Adobe-Japan1-6
Adobe-Japan2-0
Adobe-Korea1-0
Adobe-Korea1-1
Adobe-Korea1-2
B5-H
B5-V
B5pc-H
B5pc-V
CNS-EUC-H
CNS-EUC-V
CNS1-H
CNS1-V
CNS2-H
CNS2-V
ETen-B5-H
ETen-B5-V
ETenms-B5-H
ETenms-B5-V
ETHK-B5-H
ETHK-B5-V
EUC-H
EUC-V
Ext-H
Ext-RKSJ-H
Ext-RKSJ-V
Ext-V
GB-EUC-H
GB-EUC-V
GB-H
GB-V
GBK-EUC-H
GBK-EUC-V
GBK2K-H
GBK2K-V
GBKp-EUC-H
GBKp-EUC-V
GBpc-EUC-H
GBpc-EUC-V
GBT-EUC-H
GBT-EUC-V
GBT-H
GBT-V
GBTpc-EUC-H
GBTpc-EUC-V
H
Hankaku
Hiragana
HKdla-B5-H
HKdla-B5-V
HKdlb-B5-H
HKdlb-B5-V
HKgccs-B5-H
HKgccs-B5-V
HKm314-B5-H
HKm314-B5-V
HKm471-B5-H
HKm471-B5-V
HKscs-B5-H
HKscs-B5-V
Hojo-EUC-H
Hojo-EUC-V
Hojo-H
Hojo-V
Identity-H
Identity-V
Katakana
KSC-EUC-H
KSC-EUC-V
KSC-H
KSC-Johab-H
KSC-Johab-V
KSC-V
KSCms-UHC-H
KSCms-UHC-HW-H
KSCms-UHC-HW-V
KSCms-UHC-V
KSCpc-EUC-H
KSCpc-EUC-V
NWP-H
NWP-V
RKSJ-H
RKSJ-V
Roman
UniCNS-UCS2-H
UniCNS-UCS2-V
UniCNS-UTF16-H
UniCNS-UTF16-V
UniCNS-UTF32-H
UniCNS-UTF32-V
UniCNS-UTF8-H
UniCNS-UTF8-V
UniGB-UCS2-H
UniGB-UCS2-V
UniGB-UTF16-H
UniGB-UTF16-V
UniGB-UTF32-H
UniGB-UTF32-V
UniGB-UTF8-H
UniGB-UTF8-V
UniHojo-UCS2-H
UniHojo-UCS2-V
UniHojo-UTF16-H
UniHojo-UTF16-V
UniHojo-UTF32-H
UniHojo-UTF32-V
UniHojo-UTF8-H
UniHojo-UTF8-V
UniJIS-UCS2-H
UniJIS-UCS2-HW-H
UniJIS-UCS2-HW-V
UniJIS-UCS2-V
UniJIS-UTF16-H
UniJIS-UTF16-V
UniJIS-UTF32-H
UniJIS-UTF32-V
UniJIS-UTF8-H
UniJIS-UTF8-V
UniJISB-UCS2-H
UniJISPro-UCS2-HW-V
UniJISPro-UCS2-V
UniJISPro-UTF8-V
UniJISX0213-UTF32-H
UniJISX0213-UTF32-V
UniKS-UCS2-H
UniKS-UCS2-V
UniKS-UTF16-H
UniKS-UTF16-V
UniKS-UTF32-H
UniKS-UTF32-V
UniKS-UTF8-H
UniKS-UTF8-V
V
WP-Symbol
You may for some reason be missing the Base folder. It's also in that Reqrd directory, with the CMaps folder. The files in the Base folder are:
wmbi____.afm
wmbi____.inf
wmbi____.pfb
wmbi____.pfm
wmb_____.afm
wmb_____.inf
wmb_____.pfb
wmb_____.pfm
wmi_____.afm
wmi_____.inf
wmi_____.pfb
wmi_____.pfm
wmr_____.afm
wmr_____.inf
wmr_____.pfb
wmr_____.pfm
If you would like to recieve a copy of these files, please do not hesitate to eMail me @ Stoned4Life[at]gmail[dot]com.
P.S. The files are what fixed my problem, but I cannot gurantee anything as to what may result from you useing them. Also, if this is in some way, shape, or form, against Adobe policy, F*** YOU! Fix the problem yourself next time Adobe.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 21, 2006 Apr 21, 2006
Thank you for sending me your files.
Adobe InDesign CS2 works perfectly on my machine.
mfg LuWa
Votes
Translate
Translate
Report
Report
