0 Replies Latest reply on Oct 29, 2006 2:53 PM by natmcknight
    Slideshow Problems
    natmcknight
      Hey guys, I am trying to use AS to make a slideshow for an online portfolio. Each frame contains the code, is triggered by a button and dynamically calls in files from my server to fade in and fade out at set intervals. If there is only one image in the sequence then it will only fade in (and stay up). The problem is, at times it works perfectly, at other times the transition rate becomes fast and erratic, and frames with single file sequences will fade in and out on the same image. The following code is from frame #1 and has 8 images in its sequence. Can someone please tell me if i am doing something wrong, or if this is a bug? Thanks..
