1 Reply Latest reply on Oct 31, 2008 9:54 PM by John Hall
    FlexBuilder vs. Eclipse
    sdhjosh
      I have a xml file and I want to find out where the tag data is being used in the application.
      All I see under the search menu in Flex builder is References and Declarations.
      And both returns nothing when I search for the tag string being used any where in the application.
      Also why is there no simple file or string search for the whole project in Flex Builder?
      I find it very inconvenient to work with flex builder.
      Can any one tell me how to do a simple string search that will search the entire project?
        • 1. Re: FlexBuilder vs. Eclipse
          John Hall Level 4
          I'm not set up to test right now (whether or not it works on file refs or just class/script names) but hover over the code segment and if it pops up a tooltip showing the locatoin or class associated with the snippet, press F3 and it should take you to the reference.
          As far as searching the whole project, use Control-Shift-F
