1 Reply Latest reply on Oct 31, 2008 11:51 AM by James Newton, ACP
    Stub Projector Problem
    Nathan_McClendon
      I have a stub project I have created to launch a .dir file. Here is the directory set up: Stub projector and "disc1.dir' are in the root. Then there is a folder for the linked files from the "disc1.dir" and an xtras folder. I theory I should launch the stub and because the "disc1" is in the root it should located it. Then the movie.dir should locate the linked files because they are in the same correlation as they were during the creation of "disc1.dir".
      The problem is that none of the files are being located. The stub asks where the .dir is, the .dir askes where it's linked files are. When I manually locate them it all works fine but that is no good.
      Here is what the stub code is:
      on exitFrame me
      go movie "disc1"
      end
      I also tried:
      on exitFrame me
      go movie "disc1"
      the searchPaths = [ ]
      add the searchPaths, the moviePath
      add the searchPaths, the moviePath & "linked files"
      end
      I am sure I am missing something simple and with limited lingo expertise I can't quite find what it is.
      Any help would be great.
