6 Replies Latest reply on Oct 28, 2008 8:14 AM by Newsgroup_User
    Installation and deactivation issue
    Mr_Gareth
      I brought home for the office, my copy of Dreamweaver to install on my home pc (which I understand it ok). I first installed Version4 which worked fine. Then installed the upgrades (MX and CS3). I naturally registed them all. When I try and open Dreamweaver cs3 is fails and closes before fully opening. I now wish to unistall it but worry that I will cause a problem with my office licence because I cant deactivate it before uninstalling.
      Any suggestions would be great.
        • 1. Re: Installation and deactivation issue
          Level 7
          It's not a registering problem. In your case I think this fix would solve
          your problem. Anyway you have nothing to loose.
          After reading a few post and google search this solution seems to fix your
          problem
          It is a corrupted file called WinFileCache-[random_numbers].dat. You will
          find this file on Windows XP, it's located at
          C:\Documents and Settings\<username>\Application Data\Adobe\Dreamweaver
          9\Configuration
          Where 9 could be different depending on your version.
          Simply delete the file and restart Dreamweaver.
          Hope this helps
          aka Frenchy ASP
          "Mr_Gareth" <webforumsuser@macromedia.com> wrote in message
          news:ge57k5$h02$1@forums.macromedia.com...
          > Hi,
          > home pc
          > Then
          > try
          > wish
          > licence
          > Thanks
          • 2. Re: Installation and deactivation issue
            Level 7
            Is your home system an Acer?
            Murray --- ICQ 71997575
            Adobe Community Expert
            (If you *MUST* email me, don't LAUGH when you do so!)
            http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
            http://www.dwfaq.com - DW FAQs, Tutorials & Resources
            > Hi,
            > home pc
            > Then
            > try
            > wish
            > licence
            > Thanks
            • 3. Re: Installation and deactivation issue
              Mr_Gareth Level 1
              Yes it is a Acer. How did you guess?
              • 4. Re: Installation and deactivation issue
                Level 7
                Because Acers have problems due to some security application that's included
                in the default installation. Search this forum for "Acer" and you'll
                see....
                news:ge793e$eo4$1@forums.macromedia.com...
                • 5. Re: Installation and deactivation issue
                  Mr_Gareth Level 1
                  Thanks. When i get home I will give it a try, but it sounds like the answer I need.
                  Thanks again.
                  • 6. Re: Installation and deactivation issue
                    Level 7
                    Here is the post
                    http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=72&catid=674&threadid =1391324&enterthread=y
                    aka Frenchy ASP
                    "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
                    news:ge79ak$f0a$1@forums.macromedia.com...
                    > included in the default installation. Search this forum for "Acer" and
                    > you'll see....
