11 Replies Latest reply on May 21, 2007 6:36 AM by (kurtoglunakliyat.com)
    How to run ALM in parallel to other FlexLM instances in one server
      We have tried to install the ALM on a server with an other Flexlm instance already running. The other FlexLM uses port 27000 already. Although we change the port of ALM to 27002 (for example) we are not able to start the ALM in a proper way. It always detects the other instance and does not function properly. The ALM Charging tool seems to work OK and shows all licenses we have. But the ALM does not find or use those.
      What to do to use the ALM on a central license server where different FlexLM license packages are maintained? Usually this is no problem, we use FlexLM since years.
