I have a similar problem and JBoss doen't started after this message:
D:\jboss\bin>run.bat -c all
JBoss Bootstrap Environment
JBOSS_HOME: D:\jboss\bin\\..
JAVA: C:\Programme\Java\jdk1.6.0\bin\java
JAVA_OPTS: -Dadobeidp.serverName=server1 -DCASBOOTPROPS=bam.properties -Dcom.
celequest.bootstrap.envpropname=CASBOOTPROPS -Dfile.encoding=utf8 -Djava.net.pre
ferIPv4Stack=true -Dprogram.name=run.bat -Djava.security.manager -Djava.security
.policy=../server/all/conf/server.policy -Djava.security.debug=failure -XX:MaxPe
rmSize=256m -Xms256m -Xmx1024m
CLASSPATH: C:\Programme\Java\jdk1.6.0\lib\tools.jar;D:\jboss\bin\\run.jar
15:51:41,812 INFO [Server] Starting JBoss (MX MicroKernel)...
15:51:41,812 INFO [Server] Release ID: JBoss [Zion] 4.0.3SP1 (build: CVSTag=JBo
ss_4_0_3_SP1 date=200510231054)
15:51:41,812 INFO [Server] Home Dir: D:\jboss
15:51:41,812 INFO [Server] Home URL: file:/D:/jboss/
15:51:41,812 INFO [Server] Patch URL: null
15:51:41,812 INFO [Server] Server Name: all
15:51:41,812 INFO [Server] Server Home Dir: D:\jboss\server\all
15:51:41,812 INFO [Server] Server Home URL: file:/D:/jboss/server/all/
15:51:41,812 INFO [Server] Server Temp Dir: D:\jboss\server\all\tmp
15:51:41,828 INFO [Server] Root Deployment Filename: jboss-service.xml
15:51:42,093 INFO [ServerInfo] Java version: 1.6.0,Sun Microsystems Inc.
15:51:42,093 INFO [ServerInfo] Java VM: Java HotSpot(TM) Client VM 1.6.0-b105,S
15:51:42,093 INFO [ServerInfo] OS-System: Windows 2003 5.2,x86
15:51:42,453 INFO [Server] Core system initialized
15:51:44,515 INFO [WebService] Using RMI server codebase:
http://TOXSERVER2:8083/
15:51:44,531 INFO [Log4jService$URLWatchTimerTask] Configuring from URL: resour
ce:log4j.xml
15:51:59,156 ERROR [URLDeploymentScanner] Incomplete Deployment listing:
--- Packages waiting for a deployer ---
org.jboss.deployment.DeploymentInfo@1d564b40 { url=file:/D:/jboss/server/all/dep loy/adobe-ds-jboss-mysql.xml }
deployer: null
status: null
state: INIT_WAITING_DEPLOYER
watch: file:/D:/jboss/server/all/deploy/adobe-ds-jboss-mysql.xml
altDD: null
lastDeployed: 1186494719156
lastModified: 1186494719156
mbeans:
--- Incompletely deployed packages ---
deployer: null
status: null
altDD: null
mbeans:
If this also can be ignored, how can i start JBoss?
Thank you
