I deploy the code at JBoss and it works.
I deploy the same code at Oracle Application Server (localhost:80)
invoking JBoss (localhost:8080) where LiveCycle Server Runs.
Exception thrown:
javax.naming.CommunicationException: Failed to retrieve stub from server 192.168.10.160:1100 [Root e
xception is java.io.StreamCorruptedException: unexpected block data]
(The goal is to deploy the Custom Application at Oracle Application Server with the LiveCycle running at JBoss). Are there any restrictions?)
My Code is the following:
package clientcontextproject;
import java.io.IOException;
import com.adobe.formServer.client.EJBClient;
import com.adobe.formServer.interfaces.IOutputContext;
import java.util.Hashtable;
import javax.naming.InitialContext;
import javax.servlet.*;
import javax.servlet.http.*;
public class ContextServlet extends HttpServlet {
private static final String CONTENT_TYPE = "text/html; charset=windows-1253";
public void init(ServletConfig config) throws ServletException {
super.init(config);
public void doPost(HttpServletRequest request,
HttpServletResponse response) throws ServletException, IOException {response.setContentType(CONTENT_TYPE);
EJBClient formServer = new EJBClient();
Hashtable propsJNDI = new Hashtable();
propsJNDI.put("java.naming.factory.initial","org.jnp.interfaces.NamingContextFactory");
propsJNDI.put("java.naming.provider.url","jnp://localhost:8080");
propsJNDI.put("java.naming.factory.url.pkgs","org.jboss.naming:org.jnp.interfaces");
try {
InitialContext initialContextOb = new InitialContext(propsJNDI);
formServer.setInitialContext(initialContextOb);
String sFormQuery="MyFile.xdp";
String sFormPreference="MSDHTML"; //
String sContentRootURI="C:\\InfoQuest\\JDevApp\\PDFRepository";
String sTargetURL="HandleData3";
String sApplicationWebRoot="http://localhost:80/MyWebRoot";
byte [] cData= new byte[0];
IOutputContext myOutputContext=formServer.renderForm(
sFormQuery,
sFormPreference,
cData,
"CacheEnabled=False",
null,
sApplicationWebRoot,
sTargetURL,
sContentRootURI,
null
ServletOutputStream oOutput=response.getOutputStream();
response.setContentType(myOutputContext.getContentType());
int outLength=myOutputContext.getOutputContent().length;
byte[] cContent=new byte[outLength];
cContent=myOutputContext.getOutputContent();
oOutput.write(cContent);
catch(Exception e)
{response.sendError(HttpServletResponse.SC_INTERNAL_SERVER_ERROR,e.getMessage());} } }
It seems that the problem occured after loading the interface: org.jnp.interfaces.NamingContext (jbossall-client-2001-04-03.jar)
which uses org.jboss.logging.Logger Class (jboss-common.jar).
At the line:
IOutputContext myOutputContext=formServer.renderForm(...)
the Exception mentioned above was thrown.
As build Libraries (from JDeveloper) I used:
J2EE,JSP Runtime libs of JDeveloper
and FormServer-client.jar,Adobe-common.jar,Axis.jar,Jaxrpc-impl.jar
As run time libraries (at WEB-INF/lib):
(From Axis1.4):axis.jar,commons-discovery-0.2.jar,commons-logging-1.0.4.jar,jaxrpc.jar
and jbossall-client-2001-04-03.jar,jboss-common.jar
Aris
