5 Replies Latest reply on Oct 29, 2008 4:41 AM by Newsgroup_User
    Have list of site changes: Can DW CS3's Find-and-Replace be driven by a script?  Or...?
    hen3ry Level 1
      Folks:
      DW CS3 MacOS 10.4.x.11
      I am renovating a site of 100+ pages. This requires making some systematic edits, which I would like to automate as much as possible -- using the DW Find-and-Replace mechanism if possible.
      I don't think the nature of the changes is particularly relevant, but I'll share it: I need to remove hundreds of mailto's from the old code and replace them with links to a common Contact form, with the specific email address supplied as a parameter. There's a bit of re-arrangement to do. I think a true regexp expert might be able to handle the job completely using regular expressions, as DW Find-and-Replace is capable, but I'm not nearly skilled enough.
      I have a text file listing of changes I need to make, something like this:
      file1: old-html-text1 ---> new-html-text1
      file2: old-html-text2 ---> new-html-text2
      fileM: old-html-textN ---> new-html-textN
      There are 150+ of these.
      Is there a way to feed such a file to DW as a script? Obviously, I'm willing to edit the text file as needed.
      The only alternative I can figure out is to use UNIX command-line tools, but that seems a bit heavy-handed -- those tools don't know about the composition of the site and they don't know anything about HTML. DW Find-and-Replace has awareness of both -- which somehow seems to be a worthwhile advantage. I'm also exploring scripting capabilities of the programmer's editor jEdit.
      Or should I just bite the bullet, get out a bottle of pain-reliever tablets, and do the 150+ edits manually?
      Am I missing something incredibly obvious?
      TIA,
      Henry
        • 1. Re: Have list of site changes: Can DW CS3's Find-and-Replace   be   driven by a script?  Or...?
          Level 7
          hen3ry wrote:
          > Folks:
          Perhaps you could give an example:
          Change this: <a href="mailto:example@example.com">
          To this: ??
          Mick
          > enough.
          > TIA,
          > Henry
          • 2. Re: Have list of site changes: Can DW CS3's Find-and-Replace be driven by a script?  Or...?
            hen3ry Level 1
            Michael White:
            My question is about scripting, preferably within DW, to make lots of repetitive changes, not about the specific nature of the changes. Since you ask, here's a generalized model for what I have in mind:
            <a href="mailto:example@sample.com">Homer Simpson</a>
            to something like
            <a href="mailform.php?a=example&b=sample&c=com&d=Homer&e=Simpson">Contact Homer Simpson<a>
            Henry
            • 3. Re: Have list of site changes: Can DW CS3's   Find-and-Replace be   driven by a script?  Or...?
              Level 7
              hen3ry wrote:
              > Michael White:
              > to something like
              > Homer Simpson<a>
              > Henry
              look for: mailto:([^@]*)@([^.]*)\.([^"]*)">([^ ]*) ([^"]*)"
              Replace with: mailform.php?a=$1&b=$2&c=$3&d=H$4&e=$5">Contact $4 $5</a>
              Mick
              • 4. Re: Have list of site changes: Can DW CS3's Find-and-Replace be driven by a script?  Or...?
                hen3ry Level 1
                Mick:
                So... the answer is "No need to script, no way to script in DW, just use the right regexp magic in the DW search-and-replace."
                Right, that works! Provided someone is kind enough to provide the regexp magic -- You. Thank you very much!
                Ummm, maybe you were challenging me, because I found your search string lacked a trailing
                </a>
                at the end and your replace string included an un-needed 'H' character.
                Thanks for the ready-made solution, and the encouragement that even mere mortals like me can use regexes. I sorta, kinda understand what you did... but it would take me hours and hours to do it from scratch.
                Thanks for helping me get rid of hundreds of mailtos: my clueless predecessor left me!
                Problem solved.
                Henry
                • 5. Re: Have list of site changes: Can DW CS3's   Find-and-Replace be   driven by a script?  Or...?
                  Level 7
                  hen3ry wrote:
                  > Mick:
                  > lacked a trailing
                  > </a>
                  oops
                  The 5 parenthesised expressions are simple enough:
                  $1. Anything but an "@", followed by an "@".
                  $2. Similarly, a full stop. (Note the escape: "\." )
                  $3 "
                  $4. [space]
                  $5."
                  Bada Bing.
                  Mick
                  > left me!
                  > Problem solved.
                  > Henry
