0 Replies Latest reply on Jul 17, 2006 10:33 AM by ptevonian
    Animated GIF ignoring frame timing
    ptevonian
      I am trying to create simple animated GIFs with a few layers of text that simply fade in and fade out in sequence. My initial attempt worked perfectly. Most frames use the default 7/100's of a second delay as they fade. A few frames were manually set to much longer delays so that the text pauses, before fading out to be replaced by the next text.
      When I reopened the file, to adjust the background color, and then re-saved it, the GIF now plays straight through, ignoring the timing of each frame. Nothing I do now can get it to pause on the appropriate frames. I've tried cutting the symbols out and pasting them into a new file, removing the animation from the symbols and reapplying it, etc.
      Any ideas, anyone?
      Thanks in advance.
