2 Replies Latest reply on Nov 10, 2008 10:35 AM by Newsgroup_User
    Exporting Layers to Files
    ~Marcus~
      I have a file which is a button and then around 150 layers of different text for each button needed for a site. When using File/Export and the "Layers to Files" option it exports the blank button and then all of the text layers with a transparent background.
      How can I export all of the layers but with the button layer used as a master to create a background for all of the other layers?
        • 1. Re: Exporting Layers to Files
          Dave Hogue Level 2
          Marcus,
          I assume that the button graphic only appears on one layer and that only text is placed on the other layers, because that will produce the outcome you have described.
          Layers can be shared across pages or across Frames (CS3) / States (CS4), but when you place an object on the "bottom" layer it will appear to be behind every layer "above" it without actually being on that layer. When you export layers to pages, you get only what is actually on each layer.
          You should use Frames / States to create your buttons, not just Layers. Draw your button graphic on one Layer, then share that layer across all Frames / States (if you are using CS3 or lower, it is in the panel's context menu; if you are using CS4, you can right-click and share from the context menu.) Then go into the Frames / States panel and create a new frame for each button label and put a different text object on each Frame / State. Since you shared the button graphic layer to each Frame / State, the button label text will appear on a button graphic on each Frame.
          When you export, make sure you select Frames / States to Files, and you will get a separate file for each button.
          (I think there are some extensions / commands available to distribute Layers to Frames / States, so this could save you the time and effort of having to copy or re-type your button labels on separate Frames / States. Unfortunately I don't have a link for you. Sorry!)
          • 2. Re: Exporting Layers to Files
            Level 7
            dhogue wrote:
            > Marcus,
            > described.
            John Dunning has a ton of cool extensions. Mostly written for CS3, but
            they may also work for CS4.
            http://johndunning.com/fireworks/
            Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
            http://www.communityMX.com/
            CommunityMX - Free Resources:
            http://www.communitymx.com/free.cfm
            .:Adobe Community Expert for Fireworks:.
            http://tinyurl.com/2a7dyp
            .:Author:.
            Lynda.com - http://movielibrary.lynda.com/authors/author/?aid=188
            Peachpit Press -
            http://www.peachpit.com/authors/bio.aspx?a=d98ed798-5ef0-45a8-a70d-4b35fa14c9a4
            Layers Magazine - http://www.layersmagazine.com/author/jim-babbage
