0 Replies Latest reply: Nov 14, 2008 12:06 PM by macduff40 RSS
    docking
    macduff40 Community Member
      found it by searching again in this forum for the word 'floating'
      got this:
      Tip: Re-Docking Resource Windows
      In HomeSite you can un-dock or float one or more of the resource windows easily by double-clicking on the top title area of the resource window.
      However, it's not clear how to re-dock them, and the HS help doesn't really tell you how either.
      To dock them, you'll have to repeat this action for each resource tab.
      Right-mouse-click over the area within each tab and select Move (tab-name) to Left.
      Here are some screen shots illustrating this:
      1. Undocking
      2. Undocked
      3. Redocking
      Note that the local file tabs may be floating with just the folders list showing. You can't get that "Move to Left" menu option if you click over the folders list, but must drag the bottom down or the folders/files list separator bar up so you can see the files list. Then Right click over the files list and select Move Files 1 (or 2) to Left..
      For some reason, you may need to re-dock some of the other tabs like help or snippets before re-docking the Local Files tabs.
      See also Ben Forta's tip: Prevent Accidental Resource Tab Moves.
