7 Replies Latest reply on Aug 17, 2007 11:43 AM by Jasmin Charbonneau
    processing collections
    Ruytero
      I have implemented an EmailEndpoint. It polls for emails with pdf's attached.
      These pdf's can have multiple attachments. Now I have been able to get these pdf's in an collection with the processFormSubmission process.
      But how do I create a loop that can process all of these attachments in the List object, for example write them to a local drive or create pdf's?
      And is it in the same way possible to loop throw a collection of pdf's that where attached to the email?
      RonnyR
        • 1. Re: processing collections
          Jasmin Charbonneau Level 4
          It's definitely possible to create a process that loop through a list.
          What I would do is first have a setValue operation that gets the number of item in your list. There is an xPath expression get-collection-size() that will return you the size.
          Then have a counter variable initialized to 0. Then get the element from the list that corresponds to the counter value. You can use xPath expression /process_data/yourListVar[coutner] and put it in a document variable.
          Finally increment the counter and loop back to the beginning.
          So you'll be able to loop throw a collection of pdf's that where attached to the email.
          Jasmin
          • 2. Re: processing collections
            Ruytero Level 1
            Thanks Jasmin8
            • 3. Re: processing collections
              Ruytero Level 1
              To put values in a map can I use something like this:
              /process_data/mapTmp[/process_data/@counter]
              Excpression:
              /process_data/@tmpDocument
              Because I want to make a loop to convert a List to a Map.
              The reason is because I am processing a dynamic form with attachments and I take the data and the attachments from that form and merge the data with a static form and than add the attachments to this static form.
              When processing a form the attachments need to be stored in a List variable but when rendering a form u you need a Map to add attachments to a form. Why is this anyway????!! Is this done to make it a little more dificult???!!
              Greetings,
              RonnyR
              • 4. Re: processing collections
                Ruytero Level 1
                I have been trying some more for putting a value in a Map-collection:
                Expression:
                id='/process_data/@counter', value='/process_data/tmpDocument'
                Location
                Expression
                /process_data/@counter, /process_data/tmpDocument
                Location
                /process_data/mapTmp[]
                Expression
                Location
                Expression
                '/process_data/@counter', '/process_data/tmpDocument'
                Location
                /process_data/mapTmp[id='/process_data/@counter']
                Expression
                And a lot of other ways but I always keep getting the error:
                java.lang.RuntimeException: Cannot create a map entry without a key specified.
                How is an Xpath excpression like this made??
                I'm getting desperate here.
                RonnyR
                • 5. Re: processing collections
                  If you want to put something in a Map you need to specify a key. It's not indexed like a list so code like /process_data/mapTmp[/process_data/@counter] would not work since there is not key for that element. You won't be able to retrieve it.
                  You need to use a SetValue operation and assign the value of your document to the map entry using the following syntax : /process_data/mapTmp[@id=keyname].
                  You can use the same syntax to retrieve an element from the map. You just need the key and it'll return you the object.
                  I hope this clears things up.
                  Jasmin
                  • 6. Re: processing collections
                    Ruytero Level 1
                    So should this work:
                    /process_data/mapTmp[@id=/process_data/@counter]
                    Expression:
                    as the Mappings-propertie of my SetValue process?
                    @counter is my counter variable that I want to use as the keyValue
                    Grz,
                    • 7. Re: processing collections
                      Yes. That should work.
                      Jasmin
