19 Replies Latest reply on Mar 2, 2009 3:30 PM by parth pandya
    Problem starting Workspace (ALC-WKS-007-000)
    rveldpau
      I can't get into Workspace. I try to login and it just returns "An error occurred during the operation. Please try again or contact your system administrator for assistance. (ALC-WKS-007-000)"
      I managed to get in once... somehow and then a whole bunch of other errors appeared. Any ideas?
      Rob V.
        • 1. Re: Problem starting Workspace (ALC-WKS-007-000)
          rveldpau Level 1
          More about this... in the server logs I have found that I'm getting the error ALC-WKS-005-002: Authentication error: a problem occured creating the default queue for user "administrator".
          • 2. Re: Problem starting Workspace (ALC-WKS-007-000)
            Jasmin Charbonneau Level 4
            Are you using the Administrator/password account. If not make sure your user has the Workspace user role associated with him.
            Jasmin
            • 3. Re: Problem starting Workspace (ALC-WKS-007-000)
              Rob,
              Have you resolve the issue? I have a similar issue, where sometimes I'm able to get in, but other time I couldn't with the same error message that you got.
              Thanks for any help!
              • 4. Re: Problem starting Workspace (ALC-WKS-007-000)
                Make sure the user you are using has the role "Workspace User" associated with them.
                You can assign roles to users using the administrative console (http://localhost:8080/adminu).
                Jasmin
                • 5. Re: Problem starting Workspace (ALC-WKS-007-000)
                  Jasmin,
                  I'm also getting the same Error message ("An error occurred during the operation. Please try again or contact your system administrator for assistance. (ALC-WKS-007-000)")when i'm trying to login to workspace with administrator/password.
                  i created a new user and assigned roles to it, but still i'm failing to log in.
                  Can you please help me out.
                  • 6. Re: Problem starting Workspace (ALC-WKS-007-000)
                    Can you post the stack trace from the app server log. If you use JBoss, it'll be under Adobe\LiveCycle8\jboss\server\log\server.log.
                    Jasmin
                    • 7. Re: Problem starting Workspace (ALC-WKS-007-000)
                      Level 1
                      Hi Jasmin,
                      I'm using WebLogic, so can you please tell me the path of the server log.
                      Mamatha
                      • 8. Re: Problem starting Workspace (ALC-WKS-007-000)
                        try the following location /usr/local/bea/user_projects/domains/lc_domain/servers/lc_server1/logs/lc_server1.log
                        Jasmin
                        • 9. Re: Problem starting Workspace (ALC-WKS-007-000)
                          Level 1
                          Hi, Has this problem been resolved yet? what's the solution?
                          I just got the same error and couldn't login using administrator/password. This server is WebSphere/SQLserver. Nobody has used it for a long while, now nobody can login.
                          thanks
                          James
                          • 10. Re: Problem starting Workspace (ALC-WKS-007-000)
                            What's in the app server log?
                            Jasmin
                            • 11. Re: Problem starting Workspace (ALC-WKS-007-000)
                              Level 1
                              [12/10/07 9:15:43:213 CST] 0000c01e DSConfigurati W DSRA8201W: DataSource Configuration: DSRA8040I: Failed to connect to the DataSource. Encountered java.sql.SQLException: The TCP/IP connection to the host has failed. java.net.SocketException: Operation timed out: connect:could be due to invalid addressDSRA0010E: SQL State = 08S01, Error Code = 0.
                              • 12. Re: Problem starting Workspace (ALC-WKS-007-000)
                                Level 1
                                There was a database connection problem, it's fixed I think, the "test connection" on the Data Source page worked. But still couldn't login with the same error code.
                                So I restarted those enterprise applications in WebSphere. But now "LiveCycle8" wouldn't start, with the following messages:
                                How to fix this please? TIA
                                [12/10/07 12:50:12:867 CST] 0000c01e SystemOut O Caused by: javax.resource.ResourceException: MessageEndpoint activation failed to find a started ResourceAdapter.
                                at com.ibm.ejs.j2c.RALifeCycleManagerImpl.activateEndpoint(RALifeCycleManagerImpl.java:1493)
                                at com.ibm.ejs.container.MessageEndpointFactoryImpl.activateEndpoint(MessageEndpointFactoryI mpl.java:257)
                                at com.ibm.ws.runtime.component.EJBContainerImpl.install(EJBContainerImpl.java:2974)
                                at com.ibm.ws.runtime.component.EJBContainerImpl.start(EJBContainerImpl.java:3653)
                                at com.ibm.ws.runtime.component.ApplicationMgrImpl.start(ApplicationMgrImpl.java:1312)
                                at com.ibm.ws.runtime.component.DeployedApplicationImpl.fireDeployedObjectStart(DeployedAppl icationImpl.java:1129)
                                at com.ibm.ws.runtime.component.DeployedModuleImpl.start(DeployedModuleImpl.java:569)
                                at com.ibm.ws.runtime.component.DeployedApplicationImpl.start(DeployedApplicationImpl.java:8 14)
                                at com.ibm.ws.runtime.component.ApplicationMgrImpl.startApplication(ApplicationMgrImpl.java: 965)
                                at com.ibm.ws.runtime.component.ApplicationMgrImpl$1.run(ApplicationMgrImpl.java:1495)
                                at com.ibm.ws.security.auth.ContextManagerImpl.runAs(ContextManagerImpl.java:3874)
                                at com.ibm.ws.security.auth.ContextManagerImpl.runAsSystem(ContextManagerImpl.java:3951)
                                at com.ibm.ws.security.core.SecurityContext.runAsSystem(SecurityContext.java:245)
                                at com.ibm.ws.runtime.component.ApplicationMgrImpl.startApplication(ApplicationMgrImpl.java: 1500)
                                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                                at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
                                at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
                                at java.lang.reflect.Method.invoke(Method.java:615)
                                at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:62)
                                at sun.reflect.GeneratedMethodAccessor139.invoke(Unknown Source)
                                at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:265)
                                at javax.management.modelmbean.RequiredModelMBean.invokeMethod(RequiredModelMBean.java:1089)
                                at javax.management.modelmbean.RequiredModelMBean.invoke(RequiredModelMBean.java:971)
                                at com.sun.jmx.mbeanserver.DynamicMetaDataImpl.invoke(DynamicMetaDataImpl.java:231)
                                at com.sun.jmx.mbeanserver.MetaDataImpl.invoke(MetaDataImpl.java:238)
                                at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerIntercepto r.java:833)
                                at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:802)
                                at com.ibm.ws.management.AdminServiceImpl$1.run(AdminServiceImpl.java:1080)
                                at com.ibm.ws.security.util.AccessController.doPrivileged(AccessController.java:118)
                                at com.ibm.ws.management.AdminServiceImpl.invoke(AdminServiceImpl.java:973)
                                at com.ibm.ws.management.commands.AdminServiceCommands$InvokeCmd.execute(AdminServiceCommand s.java:251)
                                at com.ibm.ws.console.core.mbean.MBeanHelper.invoke(MBeanHelper.java:239)
                                at com.ibm.ws.console.appdeployment.ApplicationDeploymentCollectionAction.execute(Applicatio nDeploymentCollectionAction.java:536)
                                at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
                                at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
                                at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1486)
                                at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:528)
                                at javax.servlet.http.HttpServlet.service(HttpServlet.java:763)
                                at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
                                at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:989)
                                at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:930)
                                at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:118)
                                at com.ibm.ws.webcontainer.filter.WebAppFilterChain._doFilter(WebAppFilterChain.java:87)
                                at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:761)
                                at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:673)
                                at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:498)
                                at com.ibm.ws.wswebcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:464)
                                at com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.forward(WebAppRequestDispatcher.ja va:308)
                                at org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1070)
                                at org.apache.struts.tiles.TilesRequestProcessor.doForward(TilesRequestProcessor.java:273)
                                at org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:455)
                                at org.apache.struts.tiles.TilesRequestProcessor.processForwardConfig(TilesRequestProcessor. java:319)
                                at com.ibm.isclite.container.controller.InformationController.processForwardConfig(Informati onController.java:159)
                                at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:279)
                                at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:145)
                                at com.ibm.ws.console.core.servlet.WSCUrlFilter.setUpCommandAssistence(WSCUrlFilter.java:792 )
                                at com.ibm.ws.console.core.servlet.WSCUrlFilter.continueStoringTaskState(WSCUrlFilter.java:3 63)
                                at com.ibm.ws.console.core.servlet.WSCUrlFilter.doFilter(WSCUrlFilter.java:229)
                                at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java: 190)
                                at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:130)
                                at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.jav a:90)
                                at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:744)
                                at com.ibm.ws.wswebcontainer.WebContainer.handleRequest(WebContainer.java:1433)
                                at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:100)
                                at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink .java:465)
                                at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewInformation(HttpInboundLink .java:394)
                                at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.jav a:102)
                                at com.ibm.ws.ssl.channel.impl.SSLReadServiceContext$SSLReadCompletedCallback.complete(SSLRe adServiceContext.java:1815)
                                at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionLi stener.java:152)
                                at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:213)
                                at com.ibm.io.async.AbstractAsyncFuture.fireCompletionActions(AbstractAsyncFuture.java:195)
                                at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:136)
                                at com
                                • 13. Re: Problem starting Workspace (ALC-WKS-007-000)
                                  It looks like it can't connect to the database anymore.
                                  Have you tried restarting the application server?
                                  Jasmin
                                  • 14. Re: Problem starting Workspace (ALC-WKS-007-000)
                                    Level 1
                                    in the process of trying to do just that... if only I could cut through all those buerocratic roadblocks.
                                    • 15. Re: Problem starting Workspace (ALC-WKS-007-000)
                                      Level 1
                                      Restart WebSphere fixed the problem. After the "Data Source" got re-configured, need to restart WebSphere.
                                      • 16. Re: Problem starting Workspace (ALC-WKS-007-000)
                                        For What It's Worth: we found that users were being locked out of Workspace with LiveCycle ES installed on WebLogic 9.2.
                                        There is a hard coded reference to Port 7001 deep inside Livecycle ES.
                                        When the problem occurred we were running the Weblogic Console on a dedicated domain - listening on port 7001. And we were running the livecycle ears on another domain - listening on another port.
                                        To fix it we reconfigured the port number to 7001 of the domain that the livecycle ear files were on.
                                        If you have any questions feel free to contact us.
                                        Lachlan
                                        http://www.avoka.com
                                        • 17. Re: Problem starting Workspace (ALC-WKS-007-000)
                                          HowardTreisman Level 1
                                          There is a file called: adobe-workspace-runtime.war\WEB-INF\classes\com\adobe\workspace\livecycle.properties
                                          that you can modify to change your port settings.
                                          (If this is the problem you're experiencing.)
                                          Thanks to Uday of Adobe Support for this tip.
                                          Howard
                                          • 18. Re: Problem starting Workspace (ALC-WKS-007-000)
                                            I'm having this same problem but with Jboss. Adding a user to the workspace role didn't help and I've restarted the app server a few times.
                                            • 19. Re: Problem starting Workspace (ALC-WKS-007-000)
                                              parth pandya
                                              Hi Guys,
                                              The problem with the Weblogic port and users not been able to login to workspace has been resolved in LC 8.2 SP1.
                                              We upgraded the LCES server to 8.2 and it solved the problem.
                                              regards,
                                              Parth
