1 Reply Latest reply on Jun 19, 2007 7:11 AM by (Kim_Laundry)
    Calling LiveCycle Data Services from a Flex application within AIR
      Hi there,
      I was experimenting with AIR by migrating some of the Flex TestDrive sample applications and trying to run them as stand-alone apps. Following the examples I found on some blogs, I managed to run the applications that use WebService and HTTPService. However, RemoteObject components fail to detect the destinations associated with the remoting service. A simple remoting example from the TestDrive is "Sample 3: Accessing data using Java RPC" and it produces the following error when running it as an AIR app:
      [RPC Fault faultString="No destination with id 'product' is registered with any service." faultCode="Server.Processing" faultDetail="null"]
      I would be grateful for any suggestions.
      Note: I hard-coded the endpoints of all the services in services-config.xml to point to my local JBoss server.
