13 Replies Latest reply on Jun 23, 2009 5:36 AM by S.Mohammad
    NameNotFoundException while calling FormService generatePDFOutput in a process
    Level 1
      Hi All,
      I have created a process which calls only one service, that is FormService generatePDFOutput. I have created three variables xfaForm for form, Document variables for inputXMLData and outputPDF. I have assigned these variables in the generatePDFOutput properties.
      I am getting the following error,
      Caused by: javax.naming.NameNotFoundException
      at com.adobe.formServer.PA.XMLFormAgentWrapper.doPAExecute(XMLFormAgentW
      rapper.java:278)
      ... 68 more
      at com.adobe.idp.dsc.provider.impl.base.AbstractResponseHolder.handleExc
      eption(AbstractResponseHolder.java:136)
      at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.doSend(EjbMe
      ssageDispatcher.java:137)
      at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(A
      bstractMessageDispatcher.java:57)
      at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:2
      08)
      at pdf.pdfpageflow.PdfpageflowController.generatePDFAction(PdfpageflowCo
      ntroller.java:61)
      at sun.reflect.GeneratedMethodAccessor188.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
      sorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:585)
      at org.apache.beehive.netui.pageflow.FlowController.invokeActionMethod(F
      lowController.java:869)
      at org.apache.beehive.netui.pageflow.FlowController.getActionMethodForwa
      rd(FlowController.java:808)
      at org.apache.beehive.netui.pageflow.FlowController.internalExecute(Flow
      Controller.java:477)
      at org.apache.beehive.netui.pageflow.PageFlowController.internalExecute(
      PageFlowController.java:305)
      at org.apache.beehive.netui.pageflow.FlowController.execute(FlowControll
      er.java:335)
      at org.apache.beehive.netui.pageflow.internal.FlowControllerAction.execu
      te(FlowControllerAction.java:51)
      at org.apache.struts.action.RequestProcessor.processActionPerform(Reques
      tProcessor.java:419)
      at org.apache.beehive.netui.pageflow.PageFlowRequestProcessor.access$201
      (PageFlowRequestProcessor.java:95)
      at org.apache.beehive.netui.pageflow.PageFlowRequestProcessor$ActionRunn
      er.execute(PageFlowRequestProcessor.java:2042)
      at org.apache.beehive.netui.pageflow.interceptor.action.internal.ActionI
      nterceptors.wrapAction(ActionInterceptors.java:90)
      It is not clear for me which Name it is not able to find. Need help please.
      Appreciate your help.
      Raghu
        • 1. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
          Jasmin Charbonneau Level 4
          The generatePDFOutput operation doesn't take an xfaForm for any of its parameters.
          The input parameter "Form" needs a string that represents the location of the xdp in the repository (ex. /Folder/myForm.xdp).
          I'm wondering if that's the cause of your problem?
          Jasmin
          • 2. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
            Level 1
            Hi Jasmin,
            Thanks for the reply.
            I have tried with you suggestion and I used a literal to indicate the form location, but still i am getting the same error.
            I am out of options.
            Any help is greatly appreciated.
            Raghu
            • 3. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
              How are you calling your process?
              If you're calling it through API, make sure to put the following jar file in your projects:
              adobe-output-client.jar
              adobe-livecycle-client.jar
              adobe-usermanager-client.jar
              Jasmin
              • 4. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
                Level 1
                Jasmin,
                Once I have added adobe-forms-client.jar in the project, the error is gone. I am getting the following error now,
                Caused by: com.adobe.livecycle.formsservice.exception.RenderFormException: java.
                lang.NullPointerException
                at com.adobe.formServer.SnapIn.PDFForm.PDFForm.getRenderPolicy(PDFForm.j
                ava:626)
                at com.adobe.formServer.SnapIn.PDFForm.PDFForm.setCommonXCIForRender(PDF
                Form.java:229)
                at com.adobe.formServer.SnapIn.PDFForm.PDFForm.setXCIForRender(PDFForm.j
                ava:190)
                at com.adobe.formServer.SnapIn.PDFForm.PDFForm.updateXCI(PDFForm.java:16
                4)
                at com.adobe.formServer.Controller.doXFARender(Controller.java:620)
                at com.adobe.formServer.Controller.doRender(Controller.java:488)
                at com.adobe.formServer.Controller.render(Controller.java:131)
                at com.adobe.formServer.FormServer.renderForm(FormServer.java:191)
                at com.adobe.formServer.FormServer.renderForm(FormServer.java:256)
                at com.adobe.formServer.docservice.FormsDocService.renderForm(FormsDocSe
                rvice.java:446)
                rvice.java:405)
                at com.adobe.formServer.docservice.FormsDocService.renderPDFForm(FormsDo
                cService.java:109)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
                java:39)
                sorImpl.java:25)
                Looks like i need to setup some policy. Any help is greatly appreciated.
                Raghu
                • 5. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
                  Level 1
                  Hi Jasmin,<br /><br />When is was setting up weblogic and deploying PDF Generator component through LC Config Manager, I got the below error<br /><br />[2007-07-18 15:21:22,468], FINE   , Thread-4, com.adobe.livecycle.lcm.feature.de<br />ployment.LCMDeployerUtil, installComponent : ..\working\deployLC\deploy\adobe-pd<br />fgconfig-dsc.jar<br />[2007-07-18 15:23:16,913], SEVERE , Thread-4, com.adobe.livecycle.lcm.feature.de<br />ployment.DeployDSCs, Failed to deploy component.<br />com.adobe.livecycle.lcm.core.LCMException[ALC-LCM-030-200]: Failed to deploy com<br />ponent.<br />        at com.adobe.livecycle.lcm.feature.deployment.DeployDSCs.deployDSCFiles(<br />DeployDSCs.java:361)<br />        at com.adobe.livecycle.lcm.feature.deployment.DeployDSCs.deployDSCs(Depl<br />oyDSCs.java:117)<br />        at com.adobe.livecycle.lcm.feature.deployment.DeployDSCsTask$ActualTask.<br /><init>(DeployDSCsTask.java:85)<br />        at com.adobe.livecycle.lcm.feature.deployment.DeployDSCsTask$1.construct<br />(DeployDSCsTask.java:58)<br />        at com.adobe.livecycle.lcm.core.tasks.SwingWorker$2.run(SwingWorker.java<br />:114)<br />        at java.lang.Thread.run(Thread.java:595)<br />Caused by: java.lang.RuntimeException: | [com.adobe.livecycle.usermanager.client<br />.AuthorizationManagerServiceClient] errorCode:16385 errorCodeHEX:0x4001 message:<br />Exception wrapped in DSCException is Null or NOT An Instance of UMException chai<br />nedException:ALC-DSC-012-000: com.adobe.idp.dsc.registry.ServiceNotFoundExceptio<br />n: Service: AuthorizationManagerService not found.chainedExceptionMessage:Servic<br />e: AuthorizationManagerService not found. chainedException trace:ALC-DSC-012-000<br />: com.adobe.idp.dsc.registry.ServiceNotFoundException: Service: AuthorizationMan<br />agerService not found.<br />        at com.adobe.idp.dsc.registry.service.impl.ServiceRegistryImpl.getServic<br />e(ServiceRegistryImpl.java:972)<br />        at com.adobe.idp.dsc.registry.service.impl.ServiceRegistryImpl.getHeadAc<br />tiveConfiguration(ServiceRegistryImpl.java:830)<br />        at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.resolveConfiguration(<br />ServiceEngineImpl.java:146)<br />        at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:58)<br />        at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMes<br />sage(AbstractMessageReceiver.java:88)<br /><br />Am I getting the error is the previous message because of this error.<br /><br />Any help is greatly appriciated.<br /><br />Thanks<br />Raghu
                  • 6. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
                    Level 1
                    one more thing, when i deploy foundation component it is successful. But when i validate through Config Manager, I get a popup message, 'adobe-usermanager-dsc is deployed but is not currently running'.
                    Is this an issue?.
                    Raghu
                    • 7. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
                      That is most likely the issue. Can you manually start it. You can use the adminui interface to start it (under Archive Ardministration/Service Manager).
                      Jasmin
                      • 8. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
                        Cross reference with post http://www.adobeforums.com/cgi-bin/webx/.3bc48885/2
                        Jasmin
                        • 9. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
                          Level 1
                          Hi Raghu and Jasmine,
                          We are using adobe API for workflow (Livecycle). By default, it run in JBoss server sucessfuly, but, while migrating it to Websphere server, the below error is thrown. It seems that the API codes are not able to contact the server (WAS) to invoke the method. The samle program is as below.
                          package com.nwa.pan.proxy;
                          import java.util.*;
                          import com.adobe.idp.um.api.infomodel.*;
                          import com.adobe.idp.Context;
                          import com.adobe.livecycle.usermanager.client.AuthenticationManagerServiceClient;
                          import com.adobe.livecycle.usermanager.client.DirectoryManagerServiceClient;
                          import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
                          public class Authenticate
                          public static void main(String[] args) {
                          try {
                          /*Properties ConnectionProps = new Properties();
                          ConnectionProps.setProperty("DSC_DEFAULT_EJB_ENDPOINT", "iiop://efmd2.mn.nwa.com:9080");
                          ConnectionProps.setProperty("DSC_TRANSPORT_PROTOCOL","SOAP");
                          ConnectionProps.setProperty("DSC_SERVER_TYPE", "WebSphere");
                          ConnectionProps.setProperty("DSC_CREDENTIAL_USERNAME", "administrator");
                          ConnectionProps.setProperty("DSC_CREDENTIAL_PASSWORD", "password");*/
                          ConnectionProps.setProperty("DSC_DEFAULT_EJB_ENDPOINT", "iiop://efmd2.mn.nwa.com:17440");
                          ConnectionProps.setProperty("DSC_TRANSPORT_PROTOCOL","EJB");
                          //Create a ServiceClientFactory object
                          ServiceClientFactory myFactory = ServiceClientFactory.createInstance(ConnectionProps);
                          // Create an AuthenticationManagerServiceClient object
                          AuthenticationManagerServiceClient authClient = new AuthenticationManagerServiceClient(myFactory);
                          // Authenticate the user
                          String username = "administrator";
                          String password = "password";
                          System.out.println("before");
                          AuthResult authResult = authClient.authenticate(username, password.getBytes());
                          System.out.println("after");
                          System.out.println(authResult);
                          // Get the authenticated users information
                          User authUser = authResult.getAuthenticatedUser();
                          System.out.println("Authenticated users canonical name: " + authUser.getCanonicalName());
                          System.out.println("Authenticated users domain name: " + authUser.getDomainName());
                          System.out.println("Authenticated users OID: " + authUser.getOid());
                          // For propagation purposes, initialize the principal if it has not already been set
                          DirectoryManagerServiceClient dirClient = new DirectoryManagerServiceClient(myFactory);
                          Principal principal = dirClient.findPrincipal(authUser.getOid());
                          if (principal == null)
                          Context context = myFactory.getContext();
                          context.initPrincipal(authResult);
                          System.out.println("Context: " + context.toString());
                          catch (Exception e)
                          System.out.println("Error Occurred: " + e.getMessage());
                          e.printStackTrace();
                          Config used for EJB Protocol
                          Error Obtained
                          Error Occurred: Exception wrapped in DSCException is Null or NOT An Instance of UMException| [com.adobe.livecycle.usermanager.client.AuthenticationManagerServiceClient] errorCode:16385 errorCodeHEX:0x4001 message:Exception wrapped in DSCException is Null or NOT An Instance of UMException chainedException:java.io.InvalidClassException: com.adobe.idp.dsc.authentication.PasswordCredential; local class incompatible: stream classdesc serialVersionUID = -8780765823884993748, local class serialVersionUID = 5130811361334818008chainedExceptionMessage:com.adobe.idp.dsc.authentication.PasswordCrede ntial; local class incompatible: stream classdesc serialVersionUID = -8780765823884993748, local class serialVersionUID = 5130811361334818008 chainedException trace:java.io.InvalidClassException: com.adobe.idp.dsc.authentication.PasswordCredential; local class incompatible: stream classdesc serialVersionUID = -8780765823884993748, local class serialVersionUID = 5130811361334818008
                          at java.io.ObjectStreamClass.initNonProxy(ObjectStreamClass.java:601)
                          at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1571)
                          at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1485)
                          at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1718)
                          at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1324)
                          at java.io.ObjectInputStream.readObject(ObjectInputStream.java:362)
                          at java.util.Hashtable.readObject(Hashtable.java:811)
                          at sun.reflect.GeneratedMethodAccessor26.invoke(Unknown Source)
                          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
                          at java.lang.reflect.Method.invoke(Method.java:615)
                          at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1001)
                          at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1828)
                          at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1738)
                          at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1927)
                          at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1851)
                          at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(AbstractMessageReceiv er.java:274)
                          at com.adobe.idp.dsc.provider.impl.ejb.receiver.EjbReceiverBean.invoke(EjbReceiverBean.java: 151)
                          at com.adobe.idp.dsc.provider.impl.ejb.receiver.EJSRemoteStatelessInvocation_b542628e.invoke (Unknown Source)
                          at com.adobe.idp.dsc.provider.impl.ejb.receiver._EJSRemoteStatelessInvocation_b542628e_Tie.i nvoke(_EJSRemoteStatelessInvocation_b542628e_Tie.java:161)
                          at com.adobe.idp.dsc.provider.impl.ejb.receiver._EJSRemoteStatelessInvocation_b542628e_Tie._ invoke(_EJSRemoteStatelessInvocation_b542628e_Tie.java:88)
                          at com.ibm.CORBA.iiop.ServerDelegate.dispatchInvokeHandler(ServerDelegate.java:613)
                          at com.ibm.CORBA.iiop.ServerDelegate.dispatch(ServerDelegate.java:466)
                          at com.ibm.rmi.iiop.ORB.process(ORB.java:503)
                          at com.ibm.CORBA.iiop.ORB.process(ORB.java:1553)
                          at com.ibm.rmi.iiop.Connection.respondTo(Connection.java:2680)
                          at com.ibm.rmi.iiop.Connection.doWork(Connection.java:2554)
                          at com.ibm.rmi.iiop.WorkUnitImpl.doWork(WorkUnitImpl.java:62)
                          at com.ibm.ejs.oa.pool.PooledThread.run(ThreadPool.java:118)
                          at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1469)
                          at com.adobe.livecycle.usermanager.client.ManagerServiceClient.throwNonUMExceptionAsUMExcept ion(ManagerServiceClient.java:53)
                          at com.adobe.livecycle.usermanager.client.ManagerServiceClient.handleException(ManagerServic eClient.java:90)
                          at com.adobe.livecycle.usermanager.client.AuthenticationManagerServiceClient.authenticate(Au thenticationManagerServiceClient.java:87)
                          at com.nwa.pan.proxy.Authenticate.main(Authenticate.java:38)
                          Config used SOAP Protocol
                          • 10. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
                            DaviddeBruine
                            Not sure if this will be helpful or not, but I found that you have to compile java components using the IBM Java 1.5 SDK (That comes with websphere) instead of the Sun Java 1.5 SDK when creating components for Websphere. Also make sure you have the latest updates to websphere 6.1 as the Java SDK didnt work for the base version.
                            • 11. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
                              Try the latest Sun JDK 6 at http://java.sun.com
                              http://www.layeronline.com
                              • 13. Re: NameNotFoundException while calling FormService generatePDFOutput in a process
                                S.Mohammad Level 1
                                Jasmine and Raghu,
                                         I am using RHEL 5 - 64 bit Linux on 3-Tera Virtual host with Java 5 , MySQL 5.0 and  adobe pre-configured Jboss 4.2 to install LiveCycle 8.2 and My intension is to get the Rights Management Service Installed  . After configuring the .ear files(using Rights Management alc-lfs not excluded-solution component  in the LCM CLI properties file ) and running the Jboss , I get the Jboss Running but with following Error
                                ERROR  [org.jboss.ejb.plugins.LogInterceptor] RuntimeException in method: public  abstract java.lang.Object  com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterLocal.doRequiresNe w(com.adobe.idp.dsc.transaction.TransactionDefinition,com.adobe.idp.dsc.transaction.Transa ctionCallback)  throws com.adobe.idp.dsc.DSCException:
                                ALC-DSC-000-000:  com.adobe.idp.dsc.DSCRuntimeException: Internal  error.
                                        at  com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew (EjbTransactionBMTAdapterBean.java:249)
                                Caused by:  java.lang.NoClassDefFoundError:  com/adobe/dctmconnector/config/DctmConnectorConfigBean
                                        at  java.lang.Class.getDeclaredConstructors0(Native  Method)
                                        at  java.lang.Class.privateGetDeclaredConstructors(Class.java:2357)
                                        at  java.lang.Class.getConstructor0(Class.java:2671)
                                        at  java.lang.Class.newInstance0(Class.java:321)
                                        at  java.lang.Class.newInstance(Class.java:303)
                                        at  com.adobe.idp.dsc.registry.component.impl.ComponentRegistryImpl$12.doInTransaction(Compon entRegistryImpl.java:877)
                                        at  com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew (EjbTransactionBMTAdapterBean.java:218)
                                        ... 199  more
                                2009-06-16 10:23:02,554 ERROR  [com.adobe.idp.dsc.startup.DSCStartupServlet] DSC Startup failed. Reason:  Internal error.
                                2009-06-16 10:23:02,554 WARN   [com.adobe.idp.dsc.startup.DSCStartupServlet] Unable to start the  DSCManager
                                and upon running the deploy liveCycle Component using LCM CLI task
                                ./ConfigurationManagerCLI.sh  deployLiveCycleComponets -f cli_propertyFile.txt
                                I see that few of  DSCs (especially the adobe-usermanager-dsc ) were  never started by the installer and It stopped throwing Exceptions While trying to deploy  adobe-rightsmanagement-jboss-dsc.jar.
                                Progress: [5%,    DSC already  installed, but is not started  adobe-remotingConnector-dsc.jar]
                                Progress: [8%, Deploying DSC    adobe-usermanager-dsc.jar]
                                Progress: [8%,    DSC already  installed, but is not started  adobe-usermanager-dsc.jar]
                                Progress: [11%, Deploying DSC    adobe-usermanager-util-dsc.jar]
                                Progress: [11%,    DSC already  installed, but is not started  adobe-usermanager-util-dsc.jar]
                                Progress: [14%, Deploying DSC    adobe-jobmanager-dsc.jar]
                                Progress: [14%,    DSC already  running adobe-jobmanager-dsc.jar]
                                While LCM CLI tries to install  RightsManagement DSC following exceptions are  thrown
                                [2009-06-16 10:47:16,604], INFO,  main, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, DSC not installed.  DSC will now be installed: com.adobe.livecycle.RightsManagement  /opt/adobe/livecycle8.2/deploy/adobe-rightsmanagement-jboss-dsc.jar
                                [2009-06-16 10:47:32,227], SEVERE,  main, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Failed to deploy  component  /opt/adobe/livecycle8.2/deploy/adobe-rightsmanagement-jboss-dsc.jar.
                                com.adobe.livecycle.lcm.core.LCMException[ALC-LCM-030-200]:  \ to deploy component  /opt/adobe/livecycle8.2/deploy/adobe-rightsmanagement-jboss-dsc.jar.
                                        at  com.adobe.livecycle.lcm.feature.deployment.DeployDSCs.deployDSCFiles(DeployDSCs.java:396)
                                        at  com.adobe.livecycle.lcm.feature.deployment.DeployDSCs.deployDSCs(DeployDSCs.java:149)
                                Caused by:  com.adobe.idp.common.errors.exception.IDPSystemException: nullorigin: |  [com.adobe.livecycle.usermanager.client.DirectoryManagerServiceClient]  errorCode:16385 errorCodeHEX:0x4001 message:Exception wrapped in DSCException is  Null or NOT An Instance of UMException chainedException:ALC-DSC-012-000:  com.adobe.idp.dsc.registry.ServiceNotFoundException: Service:  DirectoryManagerService not found.chainedExceptionMessage:Service:  DirectoryManagerService not found. chainedException trace:ALC-DSC-012-000:  com.adobe.idp.dsc.registry.ServiceNotFoundException: Service:  DirectoryManagerService not found.
                                I tried to look for adobe-usermanager-dsc in the admin UI but did not find one over there . I even tried copying the adobe-usermanager-dsc.jar to pre-configured Jboss server/all/lib directory but that does'nt makes a difference .
                                I was suggested to use different combinations of excluded solution  components in the cliProperties file
                                When I used the following list of   excludedSolutionComponents  I did not see the (ERROR  [com.adobe.idp.dsc.startup.DSCStartupServlet] DSC Startup failed. Reason:  Internal error.) but still the dobe-usermanager-dsc does not starts and I get the same errors of (com.adobe.idp.dsc.registry.ServiceNotFoundException: Service:  DirectoryManagerService not found.) when the LCM CLI reaches installing the Rights Management DSC.
                                excludedSolutionComponents=ALC-LFS-BusinessActivityMonitoring,ALC-LFS-ConnectorIBMContentM anager,ALC-LFS-ContentServices,ALC-LFS-PDFGenerator,ALC-LFS-ProcessManagement
                                #,ALC-LFS-RightsManagement,ALC-LFS-BarcodedForms,ALC-LFS-DigitalSignatures,ALC-LFS-Forms,A LC-LFS-Output,ALC-LFS-PDFGenerator3D,ALC-LFS-ReaderExtensions,ALC-LFS-ConnectorEMCDocument um,ALC-LFS-ConnectorIBMFileNet
                                Any help on this issue will be highly obliged.
                                Thank you.
                                Mohammad
