5 Replies Latest reply on Jun 21, 2010 8:53 AM by Srini Dhulipalla
    ALC-DSC-005-000: com.adobe.idp.dsc.DSCNotSerializableException: Not Serializable
      We've created a process with an input parameter (String) and an output parameter. There is only one "Query Single Row" node. The SQL we've put has been tested successfully. But when the client Java program invokes it, it got the exception of "ALC-DSC-005-000: com.adobe.idp.dsc.DSCNotSerializableException: Not Serializable"
        • 1. Re: ALC-DSC-005-000: com.adobe.idp.dsc.DSCNotSerializableException: Not Serializable
          Level 1
          The full trace is:
          Caused by: ALC-DSC-000-000: com.adobe.idp.dsc.DSCRuntimeException: Internal error.
          at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker. java:311)
          at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:98)
          at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:134)
          at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:44)
          at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
          at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:326)
          at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew (EjbTransactionCMTAdapterBean.java:272)
          at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionCMTAdapter_ caf58c4f.doRequiresNew(Unknown Source)
          at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:143)
          at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
          at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
          at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:93)
          at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:47)
          at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:113)
          at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:102)
          at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(AbstractMessageReceiv er.java:298)
          at com.adobe.idp.dsc.provider.impl.ejb.receiver.EjbReceiverBean.invoke(EjbReceiverBean.java: 146)
          at com.adobe.idp.dsc.provider.impl.ejb.receiver.EJSRemoteStatelessInvocation_b542628e.invoke (Unknown Source)
          at com.adobe.idp.dsc.provider.impl.ejb.receiver._EJSRemoteStatelessInvocation_b542628e_Tie.i nvoke(_EJSRemoteStatelessInvocation_b542628e_Tie.java:161)
          at com.adobe.idp.dsc.provider.impl.ejb.receiver._EJSRemoteStatelessInvocation_b542628e_Tie._ invoke(_EJSRemoteStatelessInvocation_b542628e_Tie.java:88)
          at com.ibm.CORBA.iiop.ServerDelegate.dispatchInvokeHandler(ServerDelegate.java:613)
          at com.ibm.CORBA.iiop.ServerDelegate.dispatch(ServerDelegate.java:466)
          at com.ibm.rmi.iiop.ORB.process(ORB.java:503)
          at com.ibm.CORBA.iiop.ORB.process(ORB.java:1553)
          at com.ibm.rmi.iiop.Connection.respondTo(Connection.java:2680)
          at com.ibm.rmi.iiop.Connection.doWork(Connection.java:2554)
          at com.ibm.rmi.iiop.WorkUnitImpl.doWork(WorkUnitImpl.java:62)
          at com.ibm.ejs.oa.pool.PooledThread.run(ThreadPool.java:118)
          at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1469)
          Caused by: java.lang.RuntimeException: enlist: caught Exception
          at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:621)
          at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker. java:261)
          ... 32 more
          at com.adobe.idp.dsc.provider.impl.base.AbstractResponseHolder.handleException(AbstractRespo nseHolder.java:136)
          at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.doSend(EjbMessageDispatcher.java :137)
          at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:57)
          at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
          at adobe.lc.sdk.InvokeForm7ProcessUsingEJB.invokeMyService(InvokeForm7ProcessUsingEJB.java:6 9)
          at adobe.lc.sdk.InvokeForm7ProcessUsingEJB.main(InvokeForm7ProcessUsingEJB.java:42)
          • 2. Re: ALC-DSC-005-000: com.adobe.idp.dsc.DSCNotSerializableException: Not Serializable
            Jasmin Charbonneau Level 4
            What is your output parameter type?
            Can you post your java code where you call the process?
            Jasmin
            • 3. Re: ALC-DSC-005-000: com.adobe.idp.dsc.DSCNotSerializableException: Not Serializable
              Level 1
              I got this Exception when I was trying to convert the BarCode into XML. Here is my client Program.
              import java.io.File;
              import java.io.*;
              import java.io.FileInputStream;
              import java.util.Iterator;
              import java.util.List;
              import java.util.Properties;
              import javax.xml.transform.*;
              import javax.xml.transform.dom.DOMSource;
              import javax.xml.transform.stream.StreamResult;
              import com.adobe.livecycle.barcodedforms.CharSet;
              import com.adobe.livecycle.barcodedforms.Delimiter ;
              import com.adobe.livecycle.barcodedforms.XMLFormat ;
              import com.adobe.idp.Document;
              import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
              import com.adobe.livecycle.barcodedforms.client.*;
              public class Testmain {
              public static void main(String[] args) {
              try
              //Set LiveCycle ES service connection properties
              Properties ConnectionProps = new Properties();
              ConnectionProps.setProperty("DSC_DEFAULT_EJB_ENDPOINT", "t3://rndvipdev02:80");
              ConnectionProps.setProperty("DSC_TRANSPORT_PROTOCOL","EJB");
              ConnectionProps.setProperty("DSC_SERVER_TYPE", "Weblogic");
              ConnectionProps.setProperty("DSC_CREDENTIAL_USERNAME", "administrator");
              ConnectionProps.setProperty("DSC_CREDENTIAL_PASSWORD", "password");
              //Create a ServiceClientFactory object
              ServiceClientFactory myFactory = ServiceClientFactory.createInstance(ConnectionProps);
              BarcodedFormsServiceClient barClient = new BarcodedFormsServiceClient(myFactory);
              //Specify a PDF document to convert to a XDP file
              FileInputStream fileInputStream = new FileInputStream("D:\\abc\\barcode.pdf");
              Document inDoc = new Document (fileInputStream);
              java.lang.Boolean myFalse = new java.lang.Boolean(false);
              java.lang.Boolean myTrue = new java.lang.Boolean(true);
              //Decode barcoded form data
              org.w3c.dom.Document decodeXML = barClient.decode(
              inDoc,
              myTrue,
              myFalse,
              myFalse,
              myFalse,
              myFalse,
              myFalse,
              myFalse,
              myFalse,
              CharSet.UTF_8);
              //Convert the decoded data to XDP data
              List extractedData = barClient.extractToXML(
              decodeXML,
              Delimiter.Tab,
              Delimiter.Tab,
              XMLFormat.XDP);
              //Create an Iterator object and iterate through
              //the List object
              Iterator iter = extractedData.iterator();
              int i = 0 ;
              while (iter.hasNext()) {
              //Get the org.w3c.dom.Document object in each element
              org.w3c.dom.Document myDom = (org.w3c.dom.Document)iter.next();
              //Convert the org.w3c.dom.Document object to a
              //com.adobe.idp.Document object
              com.adobe.idp.Document myDocument = convertDOM(decodeXML);
              //Save the XML data to extractedData.xml
              File myFile = new File("D:\\abc\\extractedData"+i+".xml");
              myDocument.copyToFile(myFile);
              i++;
              catch(Exception e)
              e.printStackTrace();
              //This user-defined method converts an org.w3c.dom.Document to a
              public static com.adobe.idp.Document convertDOM(org.w3c.dom.Document doc)
              byte[] mybytes = null ;
              com.adobe.idp.Document myDocument = null;
              try
              //Create a Java Transformer object
              TransformerFactory transFact = TransformerFactory.newInstance();
              Transformer transForm = transFact.newTransformer();
              //Create a Java ByteArrayOutputStream object
              ByteArrayOutputStream myOutStream = new ByteArrayOutputStream();
              //Create a Java Source object
              Source myInput = new DOMSource(doc);
              //Create a Java Result object
              Result myOutput = new StreamResult(myOutStream);
              //Populate the Java ByteArrayOutputStream object
              transForm.transform(myInput,myOutput);
              //Get the size of the ByteArrayOutputStream buffer
              int myByteSize = myOutStream.size();
              //Allocate myByteSize to the byte array
              mybytes = new byte[myByteSize];
              //Copy the content to the byte array
              mybytes = myOutStream.toByteArray();
              com.adobe.idp.Document myDoc = new com.adobe.idp.Document(mybytes);
              myDocument = myDoc ;
              catch(Exception ee)
              ee.printStackTrace();
              return myDocument;
              Here is the Exception StackTrace
              Caused by: ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error.
              at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:210)
              at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:336)
              at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(Ej bTransactionCMTAdapterBean.java:212)
              at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapter_z73hg_ELOImpl.doS upports(EjbTransactionCMTAdapter_z73hg_ELOImpl.java:145)
              at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:104)
              at com.adobe.idp.dsc.provider.impl.ejb.receiver.EjbReceiverBean.invoke(EjbReceiverBean.java: 151)
              at com.adobe.idp.dsc.provider.impl.ejb.receiver.Invocation_fpvhue_EOImpl.invoke(Invocation_f pvhue_EOImpl.java:61)
              at com.adobe.idp.dsc.provider.impl.ejb.receiver.Invocation_fpvhue_EOImpl_WLSkel.invoke(ILweb logic.rmi.spi.InboundRequest;Lweblogic.rmi.spi.OutboundResponse;Ljava.lang.Object;)Lweblog ic.rmi.spi.OutboundResponse;(Unknown Source)
              at weblogic.rmi.internal.BasicServerRef.invoke(BasicServerRef.java:589)
              at weblogic.rmi.cluster.ClusterableServerRef.invoke(ClusterableServerRef.java:224)
              at weblogic.rmi.internal.BasicServerRef$1.run(BasicServerRef.java:479)
              at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:363)
              at weblogic.security.service.SecurityManager.runAs(Lweblogic.security.acl.internal.Authentic atedSubject;Lweblogic.security.acl.internal.AuthenticatedSubject;Ljava.security.Privileged ExceptionAction;)Ljava.lang.Object;(Unknown Source)
              at weblogic.rmi.internal.BasicServerRef.handleRequest(BasicServerRef.java:475)
              at weblogic.rmi.internal.BasicServerRef.access$300(BasicServerRef.java:59)
              at weblogic.rmi.internal.BasicServerRef$BasicExecuteRequest.run(BasicServerRef.java:1016)
              at weblogic.work.ExecuteThread.execute(ExecuteThread.java:200)
              at weblogic.work.ExecuteThread.run(ExecuteThread.java:172)
              Caused by: com.adobe.barcodedforms.decoder.DecodingException null: com.adobe.barcodedforms.decoder.processors.DataProcessorException: com.adobe.barcodedforms.decoder.processors.DataProcessorException
              at com.adobe.livecycle.barcodedforms.BarcodedFormsService.decode(BarcodedFormsService.java:2 97)
              at j
              • 4. Re: ALC-DSC-005-000: com.adobe.idp.dsc.DSCNotSerializableException: Not Serializable
                Han Dao Level 1
                Hi David,
                Did you ever get this problem solved? If so, could you please explain how did you get it solved.
                Han Dao
                • 5. Re: ALC-DSC-005-000: com.adobe.idp.dsc.DSCNotSerializableException: Not Serializable
                  Srini Dhulipalla Level 5
                  Try Changing the componentId and version in the component.xml and try.
