10 Replies Latest reply on Jun 6, 2008 12:13 PM by (Thiyaharajan_Siva)
    Conent Root
      Hi All,
      If i have added a form Test.xdp in resources under /Test/Forms, what will be the Cotent Root. Or is the conent root always xappstore://localhost.
      Raghu
        • 1. Re: Conent Root
          Jasmin Charbonneau Level 4
          The content root in ES is now repository://
          Your form URL will be /Test/Forms.xdp
          Jasmin
          • 2. Re: Conent Root
            Level 1
            I have set the content root as repository:// and Form literal value as /Test/Forms/Test.xdp. I am getting the following errors<br /><br />1) A message box is poped up with title 'XMLForm.exe - Unable To Locate Component' and message 'This application has failed to start because omniDynamic403_rt.dll was not found. Reinstalling the application may fix this problem.'<br /><br />2) When I say OK to the above message, I see the following error in application server stdout,<br /><br /><Jul 25, 2007 10:34:58 AM EDT> <Warning> <com.adobe.service.ProcessResource> <00<br />0000> <BMC024: Service XMLFormService: Process ProcessResource(name=XMLForm.exe,<br />pid=0) terminated abnormally with error code {3}><br /><Jul 25, 2007 10:34:58 AM EDT> <Error> <com.adobe.formServer.PA.XMLFormAgentWrap<br />per> <000000> <ALC-FRM-001-004: Unable to find service: XMLFormService, error: C<br />onnection to failed service.><br />com.adobe.printSubmitter.PrintException: java.lang.IllegalStateException: Connec<br />tion to failed service. in com.adobe.livecycle.formsservice.exception.RenderForm<br />Exception, cause: java.lang.IllegalStateException: Connection to failed service.<br /> in com.adobe.livecycle.formsservice.exception.FormServerException<br />        at com.adobe.printSubmitter.util.FormSubmitter.submit(FormSubmitter.java<br />:124)<br />        at com.adobe.printSubmitter.util.FormSubmitter.submit(FormSubmitter.java<br />:68)<br />        at com.adobe.printSubmitter.util.Splitter.endElementNoBatch(Splitter.jav<br />a:168)<br />        at com.adobe.printSubmitter.util.Splitter.endElement(Splitter.java:187)<br />        at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endEleme<br />nt(AbstractSAXParser.java:633)<br />        at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImp<br />l.scanEndElement(XMLDocumentFragmentScannerImpl.java:1241)<br />        at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImp<br />l$FragmentContentDispatcher.dispatch(XMLDocumentFragmentScannerImpl.java:1685)<br />        at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImp<br />l.scanDocument(XMLDocumentFragmentScannerImpl.java:368)<br />        at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(X<br />ML11Configuration.java:834)<br />        at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(X<br />ML11Configuration.java:764)<br />        at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.<br />java:148)<br />        at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Ab<br />stractSAXParser.java:1242)<br />        at weblogic.xml.jaxp.WebLogicXMLReader.parse(WebLogicXMLReader.java:133)<br /><br />        at weblogic.xml.jaxp.RegistryXMLReader.parse(RegistryXMLReader.java:153)<br /><br />Any idea why I am getting this error. Appreciate your help.<br /><br />Thanks<br />Raghu
            • 3. Re: Conent Root
              I think your installation is corrupted. There are four other posts with problems you have and I think they are all related to an unstable environment.
              I'm no sure what exactly is wrong with your environment. I would suggest to re-install or try to diagnose why the environment is not responding properly before posting issues specific components.
              Have you verified your environment with configuration manager?
              Jasmin
              • 4. Re: Conent Root
                Level 1
                I re-installed, still I am getting the same error.
                I have manually deployed LiveCycle in weblogic. Did I miss any step related to native PDF?.
                Raghu
                • 5. Re: Conent Root
                  Level 1
                  Hey,
                  I am getting the similar errors I think there is a problem with the XMLFormService. Does anybody know the solution to this.
                  [3/12/08 1:45:58:850 EDT] 0000003a ProcessResour A com.adobe.service.ProcessResource startProcess BMC505: Service XMLFormService: Starting native process with command line "C:\\amsapps\\websphere61\\appserver\\installedApps\\adobe\\server1\\XMLFormService\\bin\ \XMLForm.exe" -MyPath c:\amsapps\websphere61\appserver\installedApps\adobe\server1\XMLFormService -IOR IOR:00bdbdbd0000002249444c3a636f6d2f61646f62652f736572766963652f4d616e616765723a312e3000b dbd0000000100000000000000b0000102bd0000001277696e6164767333302e616d732e636f6d000b340000001 f4c4d4249000000154773e3aa001500050442522d3400080100000000000000bd0000000700000001000000140 0bdbdbd0501000100000000000101000000000049424d0a0000000800bd0001150000010000002600000002000 2bdbd49424d04000000050005020102bdbdbd0000001f0000000400bd0003000000200000000400bd000100000 0250000000400bd0003 -AppServer websphere
                  [3/12/08 1:45:59:725 EDT] 0000003d ProcessResour A com.adobe.service.ProcessResource$ManagerImpl signalIntValue BMC508: Service XMLFormService: Native process PID = 4300
                  [3/12/08 1:46:05:584 EDT] 00000041 ProcessResour W com.adobe.service.ProcessResource$ErrorReaderThread run BMC024: Service XMLFormService: Process ProcessResource(name=XMLForm.exe,pid=4300) terminated abnormally with error code {3}
                  [3/12/08 1:46:09:740 EDT] 0000003a ProcessResour E com.adobe.service.ProcessResource onRollback BMC001: Unexpected exception while rolling back transaction
                  [3/12/08 1:46:09:740 EDT] 0000003a ProcessResour E com.adobe.service.ProcessResource onRollback TRAS0014I: The following exception was logged org.omg.CORBA.INTERNAL: initial and forwarded IOR inaccessible vmcid: IBM minor code: 58C completed: No
                  at com.ibm.rmi.corba.ClientDelegate.createRequest(ClientDelegate.java:1213)
                  at com.ibm.CORBA.iiop.ClientDelegate.createRequest(ClientDelegate.java:1320)
                  at com.ibm.rmi.corba.ClientDelegate.createRequest(ClientDelegate.java:1109)
                  at com.ibm.CORBA.iiop.ClientDelegate.createRequest(ClientDelegate.java:1286)
                  at com.ibm.rmi.corba.ClientDelegate.request(ClientDelegate.java:1816)
                  at com.ibm.CORBA.iiop.ClientDelegate.request(ClientDelegate.java:1242)
                  at org.omg.CORBA.portable.ObjectImpl._request(ObjectImpl.java:458)
                  at com.adobe.service._ControlAgentStub.done(_ControlAgentStub.java:104)
                  at com.adobe.service.ProcessResource.onRollback(ProcessResource.java:731)
                  at com.adobe.service.ResourcePeer.invokeRollback(ResourcePeer.java:124)
                  at com.adobe.service.J2EEResourcePeerImpl.afterCompletion(J2EEResourcePeerImpl.java:190)
                  at com.ibm.ws.Transaction.JTA.RegisteredSyncs.distributeAfter(RegisteredSyncs.java:424)
                  at com.ibm.ws.Transaction.JTA.TransactionImpl.distributeAfter(TransactionImpl.java:3859)
                  at com.ibm.ws.Transaction.JTA.TransactionImpl.postCompletion(TransactionImpl.java:3838)
                  at com.ibm.ws.Transaction.JTA.TransactionImpl.internalRollback(TransactionImpl.java:2751)
                  at com.ibm.ws.Transaction.JTA.TransactionImpl.stage2CommitProcessing(TransactionImpl.java:17 28)
                  at com.ibm.ws.Transaction.JTA.TransactionImpl.processCommit(TransactionImpl.java:1597)
                  at com.ibm.ws.Transaction.JTA.TransactionImpl.commit(TransactionImpl.java:1528)
                  at com.ibm.ws.Transaction.JTA.TranManagerImpl.commit(TranManagerImpl.java:237)
                  at com.ibm.ws.Transaction.JTA.TranManagerSet.commit(TranManagerSet.java:162)
                  at com.ibm.ws.Transaction.JTA.UserTransactionImpl.commit(UserTransactionImpl.java:285)
                  at com.ibm.ejs.container.UserTransactionWrapper.commit(UserTransactionWrapper.java:264)
                  at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew (EjbTransactionBMTAdapterBean.java:220)
                  at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionBMTAdapter_ 3af08fdf.doRequiresNew(Unknown Source)
                  at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:133)
                  at com.adobe.idp.dsc.transaction.impl.DefaultTransactionTemplate.execute(DefaultTransactionT emplate.java:79)
                  at com.adobe.printSubmitter.service.OutputServiceImpl.invokeGeneratePDFOutputWithSMT(OutputS erviceImpl.java:242)
                  at com.adobe.printSubmitter.service.OutputServiceImpl.generatePDFOutput(OutputServiceImpl.ja va:225)
                  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
                  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
                  at java.lang.reflect.Method.invoke(Method.java:615)
                  at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:181)
                  at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:134)
                  at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:44)
                  at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
                  at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTran sactionBMTAdapterBean.java:197)
                  at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionBMTAdapter_ 3af08fdf.doBMT(Unknown Source)
                  at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:95)
                  at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
                  at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
                  regards,
                  Sushant
                  • 6. Re: Conent Root
                    waqas.rehman
                    Hi:<br /><br />I am facing the same issue of FormService on Weblogic application server. Following is the message i am getting on the console:<br />------------------------------------------------------------<br />couldn't set locale correctly<br />ld.so.1: /opt/deg_epermit_bea9/user_projects/domains/epermit_domain/null/adobe/deg-bk-app1-ZoneAep ay1/XMLFormService/bin/XMLForm: fatal: libbsl.so: open failed: No such file or directory<br /><May 19, 2008 4:21:23 PM GMT+04:00> <Warning> <com.adobe.service.ProcessResource> <000000> <BMC024: Service XMLFormService: Process ProcessResource(name=XMLForm.exe,pid=0) terminated abnormally with error code {3}><br />couldn't set locale correctly<br />ld.so.1: /opt/deg_epermit_bea9/user_projects/domains/epermit_domain/null/adobe/deg-bk-app1-ZoneAep ay1/XMLFormService/bin/XMLForm: fatal: libbsl.so: open failed: No such file or directory<br /><May 19, 2008 4:21:24 PM GMT+04:00> <Warning> <com.adobe.service.ProcessResource> <000000> <BMC024: Service XMLFormService: Process ProcessResource(name=XMLForm.exe,pid=0) terminated abnormally with error code {3}><br /><May 19, 2008 4:21:24 PM GMT+04:00> <Error> <com.adobe.formServer.PA.XMLFormAgentWrapper> <000000> <ALC-FRM-001-004: Unable to find service: XMLFormService, error: Connection to failed service.><br />couldn't set locale correctly<br />-------------------------------------------------------------<br /><br />Did you guys found a resulotion to the issue. <br /><br />Regards,<br />Waqas
                    • 7. Re: Conent Root
                      Hello Waqas,
                      You need to add arg -Dadobeidp.RootDirectory=%DOMAIN_HOME% either in your WebLogic start script or in the managed server's argument field.
                      -Joe
                      • 8. Re: Conent Root
                        waqas.rehman Level 1
                        Hello Joe,
                        Thanks for your reply. I have already added the this argument in the weblogic startup argument.
                        -Dadobeidp.RootDirectory=/opt/deg_epermit_bea9/user_projects/domains/epermit_domain/ -Dfile.encoding=utf8 -Djava.net.pereferIPv4Stack=true -Djava.net.preferIPv4Stack=true -Djava.security.policy=/opt/deg_epermit_bea9/weblogic92/server/lib/weblogic.policy -Xms256m -Xmx2048m -XX:MaxPermSize=256m
                        Regards,
                        Waqas
                        • 9. Re: Conent Root
                          The Content Root + form URL will be repository:///Test/Forms/myForm.xdp
                          Jasmin
                          • 10. Re: Conent Root
                            am also getting the same problem
