2 Replies Latest reply on Mar 5, 2009 11:16 AM by Charles Bihis
    LCDS and JMS ObjectMessage
      I am trying to get an object from ActiveMQ and push it to my Flex client with LCDS.  I am using the JMS Adapter since the objects being put on ActivemQ are from Java.  For example:<br /><br />bJava Code Putting Message on ActiveMQ<br />ActiveMQConnectionFactory fac = new ActiveMQConnectionFactory("tcp://localhost:61616");<br />Connection conn = fac.createConnection();<br />conn.start();<br />          <br />Session sess = conn.createSession(false, Session.AUTO_ACKNOWLEDGE);<br />Destination dest = sess.createTopic("messageTopic");<br />          <br />MessageProducer producer = sess.createProducer(dest);<br />com.foo.Person person = new com.foo.Person("John Doe");<br />ObjectMessage msg = sess.createObjectMessage(person);<br />producer.send(msg);<br /><br />I have defined the object type in my "messaging-config.xml" as "javax.jms.ObjectMessage".  However, when the Flex client gets the message the "body" is null.<br /><br />bFlex Client Receiving Message from LCDS<br /><mx:Consumer id="jmsConsumer" <br />   destination="feed"<br />   message="jms_MessageHandler(event)" <br />   fault="jms_FaultHandler(event)"<br />/><br /><br />private function jms_MessageHandler(event : MessageEvent) : void {<br />    Alert.show("BODY: " + event.body);<br />}<br /><br />Any ideas why I can't get the object in Flex??
        • 1. Re: LCDS and JMS ObjectMessage
          I am developing an application and I am in a position where I can push messages to one or many AIR applications and the selection of AIR application will be decided by LCDS server. Here I am making use of JMS along with JMS adapter. I need a way to receive an acknowledgement to LCDS server when the message is delivered.
          I have found few application where JMS subscriber is sending acknowledgement to JMS producer, but I need a way where JMS producer is getting acknowledgement from each Flex client.
          • 2. Re: LCDS and JMS ObjectMessage
            Charles Bihis
            Has there been any solution to this? I'm experiencing the exact same problem.
            Charles
