2 Replies Latest reply on Oct 8, 2008 6:14 AM by (Alexandro_Mancusi)
    Managed Associations (Flex 3 \ CF 8 \ LCDS 2.5 \ MySQL 5)
      I have two tables 'jdbcuser' and 'jdbcrole' in database 'jdbcauthdwo'.<br />In have added the database as a DataSource in CF8 named 'jdbcauthdwo'.<br />In Flexbuilder I have generated the CFC's and AS files for both tables.<br />I can extract data form both tables so the CFC's and the AS files work.<br />I have setup a one-to-many relationship between the destinations of the two tables.<br />I created a flex app that has a dataservice that calls the parent destination and I recieve the data from that OK. But I recieve 'null' for the object of the child.<br />I have read through every piece of cocumentation that I can find but I can't find what I do wrong so I have posted my code below. I hope some can point out to me what's wrong.<br /><br />The channel:<br /><br />        <channel-definition id="cf-rtmp" class="mx.messaging.channels.RTMPChannel"><br />            <endpoint uri="rtmp://{server.name}:2048" class="flex.messaging.endpoints.RTMPEndpoint"/><br />            <properties><br />                <idle-timeout-minutes>20</idle-timeout-minutes><br />                <serialization><br />                    <instantiate-types>false</instantiate-types><br />                </serialization><br />            </properties><br />        </channel-definition><br /><br />The destinations:<br /><br />     <destination id="jdbcuser"><br />          <adapter ref="coldfusion-dao" /><br />          <channels><br />               <channel ref="cf-rtmp" /><br />          </channels><br />          <properties><br />               <component>dto.jdbcuserAssembler</component><br />               <scope>application</scope><br />               <metadata><br />                    <identity property = "username" /><br />                    <one-to-many property="roles" destination="jdbcrole" lazy="false" /><br />               </metadata><br />          </properties><br />     </destination><br />     <br />     <destination id="jdbcrole"><br />          <adapter ref="coldfusion-dao" /><br />          <channels><br />               <channel ref="cf-rtmp" /><br />          </channels><br />          <properties><br />               <component>dto.jdbcroleAssembler</component><br />               <scope>application</scope><br />               <metadata><br />                    <identity property = "username" /><br />               </metadata><br />          </properties><br />     </destination><br /><br />The AS scripts:<br /><br />PARENT<br /><br />package dto.auth<br />{<br />     [Managed]<br />     [RemoteClass(alias="dto.jdbcuser")]<br /><br />     public class jdbcuser<br />     {<br /><br />          public var username:String = "";<br />          public var password:String = "";<br />          public var roles:jdbcrole;<br /><br />          public function jdbcuser()<br />          {<br />          }<br /><br />     }<br />}<br /><br />CHILD<br /><br />package dto.auth<br />{<br />     [Managed]<br />     [RemoteClass(alias="dto.jdbcrole")]<br /><br />     public class jdbcrole<br />     {<br /><br />          public var username:String = "";<br />          public var role:String = "";<br /><br />          public function jdbcrole()<br />          {<br />          }<br /><br />     }<br />}<br /><br />The Flex app:<br /><br /><?xml version="1.0" encoding="utf-8"?><br /><mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical"<br />     creationComplete="{DS.fill(AC)}"><br />     <br />     <mx:Script><br />          <br />               import dto.auth.jdbcuser;<br />               import dto.auth.jdbcrole;<br />     <br />               import mx.collections.ArrayCollection;<br />               import mx.rpc.events.ResultEvent;<br />                         <br />               [Bindable]<br />               private var AC:ArrayCollection = new ArrayCollection;<br />               <br />               private function DSResultHandler(event:ResultEvent){<br />                    var e:ResultEvent = event;<br />               }<br />               <br />          <br />     </mx:Script><br />     <br />     <mx:DataService id="DS" destination="jdbcuser" result="DSResultHandler(event)"/><br />     <mx:DataGrid id="DG" dataProvider="{AC}"/><br />     <br /></mx:Application><br /><br />I fill a datagrid and I have an resulthandler in place so that I can put a breakpoitn there and see what is coming out of the dataservice.<br /><br />I get this as a result:<br /><br />result     Array (@3b8c511)     <br />     [0]     Object (@3bb0309)     <br />     [1]     Object (@3bb0359)     <br />          password     "vanburk1234"     <br />          roles     mx.collections.ArrayCollection (@3b13f01)     <br />               [inherited]     <br />               source     null     <br />          username     "jim"     <br />     [2]     Object (@3bb03a9)     <br />     length     3     <br /><br />As you can see source is null.<br />When I don't instanciate the jdbcuser object in my app I don't even get an arraucollection for roles but I get 'undefined'.<br /><br />Remeber I am not using java but coldfusion for Assemblers.<br />I want to use the managed approache so I should be fine without any extra sql code. But maybe I'm wrong or I read the docs wrong.<br /><br />Any help would be welcome.<br />Thanks in adva
        • 1. Re: Managed Associations (Flex 3 \ CF 8 \ LCDS 2.5 \ MySQL 5)
          Level 1
          [inherited]
          source null
          username "jim"
          length 3
          Thanks in advance,
          Alexandro
          • 2. Re: Managed Associations (Flex 3 \ CF 8 \ LCDS 2.5 \ MySQL 5)
            Level 1
            The first message was clipped.
            The AS code in teh app is:
                           [Bindable]
            The MXML code is:
            On creationcomplete is does DS.fill(AC)
