3 Replies Latest reply on Aug 3, 2009 9:26 AM by ma.tze
    DataServiceTransaction
      I'm running lcds on Jboss.
      I'm trying to add an object on the server and push it to the client using the DataServiceTransaction class.
      I do so by writing these lines:
      DataServiceTransaction dataTrans = DataServiceTransaction.begin(false);
      dataTrans.createItem(destinatin name, createItem);
      dataTrans.commit();
      but when running, i get the follow exception on the first line:
      Unable to locate a MessageBroker initialized with server id 'null'
      does anyone know how can i solve it??
      thanks,
      Liat
        • 1. Re: DataServiceTransaction
          Divyakumar Jain
          We you able to resolve this issue?
          I am trying to update Data on client side from Server side using DataServiceTransectionClass. These updates are triggered at regular interval using EJB Timer API on JBoss App Server
          I am facing similar issue following is stack trace
          javax.ejb.EJBException: flex.data.DataServiceException: Unable to locate a MessageBroker initialized with server id 'null'
              at org.jboss.ejb3.tx.Ejb3TxPolicy.handleExceptionInOurTx(Ejb3TxPolicy.java:77)
              at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:83)
              at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:190)
              at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
              at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
              at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
              at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationIntercep torv2.java:80)
              at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
              at org.jboss.ejb3.asynchronous.AsynchronousInterceptor.invoke(AsynchronousInterceptor.java:1 06)
              at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor .java:67)
              at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocation Interceptor.java:67)
              at org.jboss.ejb3.stateless.StatelessContainer.callTimeout(StatelessContainer.java:304)
              at org.jboss.ejb.txtimer.TimerImpl$TimerTaskImpl.run(TimerImpl.java:561)
              at java.util.TimerThread.mainLoop(Timer.java:512)
              at java.util.TimerThread.run(Timer.java:462)
          Caused by: flex.data.DataServiceException: Unable to locate a MessageBroker initialized with server id 'null'
              at flex.data.DataServiceTransaction.begin(DataServiceTransaction.java:267)
              at flex.data.DataServiceTransaction.begin(DataServiceTransaction.java:293)
              at org.divy.scheduler.QueryScheduler.runQuery(QueryScheduler.java:58)
              at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
              at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
              at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
              at java.lang.reflect.Method.invoke(Method.java:597)
              at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
              at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
              at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.jav a:69)
              at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
              at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.ja va:59)
              at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
              at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContext Interceptor.java:72)
              at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillM ethod_17490623.invoke(InvocationContextInterceptor_z_fillMethod_17490623.java)
              at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInter ceptor.java:88)
              at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup _17490623.invoke(InvocationContextInterceptor_z_setup_17490623.java)
              at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInter ceptor.java:62)
              at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedE ntityManagerInterceptor.java:56)
              at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
              at org.jboss.ejb3.stateless.StatelessInstanceInterceptor.invoke(StatelessInstanceInterceptor .java:68)
              at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:79)
          • 2. Re: DataServiceTransaction
            ma.tze
            Hi Liat,
            I think you have to install and configure JOTM first, see
            http://www.nabble.com/LCDS---Tomcat---JOTM-Integration-td18761900.html
            Cheers!
            Martin Zach
            • 3. Re: DataServiceTransaction
              ma.tze Level 1
              Hi DJ,     I think you have to install and configure JOTM first, see  http://www.nabble.com/LCDS---Tomcat---JOTM-Integration-td18761900.html     Cheers!     Martin Zach
