0 Replies Latest reply on Nov 5, 2008 9:52 AM by Mark Lindberg
    Help with Java servlet error - LiveCycle Quickstart HandleData
    Mark Lindberg Level 2
      Greetings:
      I am really struggling trying to get the LiveCycle Quickstart Servlet example working. I am encountering this error: "com.adobe.livecycle.formsservice.exception.ProcessFormSubmissionException: java.lang.IllegalStateException".
      This is occuring on this command:
      "FormsResult formOut = formsClient.processFormSubmission(formData, "CONTENT_TYPE=application/pdf&CONTENT_TYPE=application/vnd.adobe.xdp+xml&CONTENT_TYPE=tex t/xml", "", processSpec);"
      I am including the output from my print statements as well as the first portion of the source code. This is being built in Eclipse, and deployed on a LiveCycle JBoss server.
      One difference is the use of SOAP instead of EJB.
      Any help or ideas are greatly appreciated.
      Thank You
      Mark
      OUTPUT:
      2008-10-31 01:00:05,375 INFO [STDOUT] Entered doPost
      2008-10-31 01:00:05,375 INFO [STDOUT] line1
      2008-10-31 01:00:05,375 INFO [STDOUT] line2
      2008-10-31 01:00:05,406 INFO [STDOUT] line3
      2008-10-31 01:00:05,406 INFO [STDOUT] line4
      2008-10-31 01:00:05,422 INFO [STDOUT] line5
      2008-10-31 09:55:36,818 INFO [STDOUT] formData Length: 588856
      2008-10-31 09:55:36,818 INFO [STDOUT] formData getContentType: null
      2008-10-31 09:55:36,818 INFO [STDOUT] formData listAttributes: []
      2008-10-31 09:55:36,818 INFO [STDOUT] formData getClass: class com.adobe.idp.Document
      2008-10-31 09:55:36,818 INFO [STDOUT] req. Length: 588856
      2008-10-31 09:55:36,818 INFO [STDOUT] req. getContentType(): application/pdf
      2008-10-31 09:55:36,818 INFO [STDOUT] req. getAuthType(): null
      2008-10-31 09:55:36,818 INFO [STDOUT] req. getPathInfo(): null
      2008-10-31 09:55:36,834 INFO [STDOUT] line6
      CODE (snip):
      public void doPost(HttpServletRequest req, HttpServletResponse resp)
      throws ServletException, IOException {
      System.out.println("Entered doPost");
      try{
      PrintWriter pp = resp.getWriter();
      System.out.println("line1");
      //Set connection properties required to invoke LiveCycle ES
      Properties ConnectionProps = new Properties();
      //ConnectionProps.setProperty("DSC_DEFAULT_EJB_ENDPOINT", "jnp://localhost:1099");
      ConnectionProps.setProperty("DSC_DEFAULT_EJB_ENDPOINT", "http://localhost:8080");
      //ConnectionProps.setProperty("DSC_TRANSPORT_PROTOCOL","EJB");
      ConnectionProps.setProperty("DSC_TRANSPORT_PROTOCOL","SOAP");
      ConnectionProps.setProperty("DSC_SERVER_TYPE", "JBoss");
      ConnectionProps.setProperty("DSC_CREDENTIAL_USERNAME", "administrator");
      ConnectionProps.setProperty("DSC_CREDENTIAL_PASSWORD", "password");
      System.out.println("line2");
      //Create a ServiceClientFactory object
      ServiceClientFactory myFactory = ServiceClientFactory.createInstance(ConnectionProps);
      System.out.println("line3");
      //Create a FormsServiceClient object
      FormsServiceClient formsClient = new FormsServiceClient(myFactory);
      System.out.println("line4");
      //Get Form data to pass to the processFormSubmission method
      Document formData = new Document(req.getInputStream());
      System.out.println("line4a");
      formData.passivate(); // save all data supplied by the input stream
      //InputStream is = new FileInputStream(req.getInputStream());
      //Document formData = new Document(is);
      System.out.println("line5");
      System.out.println("formData Length: " + formData.length());
      System.out.println("formData getContentType: " + formData.getContentType());
      System.out.println("formData listAttributes: " + formData.listAttributes());
      System.out.println("formData getClass: " + formData.getClass());
      System.out.println("req. Length: " + req.getContentLength());
      System.out.println("req. getContentType(): " + req.getContentType());
      System.out.println("req. getAuthType(): " + req.getAuthType());
      System.out.println("req. getPathInfo(): " + req.getPathInfo());
      //Set run-time options
      RenderOptionsSpec processSpec = new RenderOptionsSpec();
      pro
