1 Reply Latest reply on Mar 6, 2009 6:45 PM by Alex Glosband
    Java Session and LCDS
      I am trying to integrate a Flex application using LCDS with a legacy web-based Java application. The legacy application makes heavy use of the java session. I am able to get the jsessionid using HTTP service calls to the application however, calling LCDS, I cannot get the session.
      I've tried the flex.messaging.getServletContext() but, this doesn't seem to be it. Any ideas would be helpful.
        • 1. Re: Java Session and LCDS
          Alex Glosband Adobe Employee
          Hi. What channel/endpoint are you using to connect to the server? If it's RTMP or a streaming or polling channel that uses the NIO server there may not be an easy way to get at the HTTP session.
          In general, I don't think it's a good idea to store stuff in the HTTPSession because it may not be available from all channels/endpoints.
          If you do need to store stuff in the session though, I'd try using a HTTP (non NIO) streaming or polling channel. I am guessing using those channels' FlexContext.getServletContext() will work to get you the HTTP session.
          -Alex
