1 Reply Latest reply on Dec 3, 2007 3:00 PM by seth_hodgson
    Samples - JOTM issue
      Guys,<br /><br />Trying desperately to get the samples working on tomcat6. After a few issues which are now resolved all the examples work apart from those using the data management facilities.<br /><br />I believe the problem is down to jotm. I've copied all the .jar files from the jotm download directory to tomcat/lib<br /><br />Any ideas?<br /><br />stack trace:<br /><br />stackTrace for: java.lang.ExceptionInInitializerError<br />org.objectweb.jotm.Current.<init>(Current.java:145)<br />org.objectweb.jotm.UserTransactionFactory.getObjectInstance(UserTransactionFactory.java :67)<br />org.apache.naming.factory.TransactionFactory.getObjectInstance(TransactionFactory.java: 110)<br />javax.naming.spi.NamingManager.getObjectInstance(NamingManager.java:304)<br />org.apache.naming.NamingContext.lookup(NamingContext.java:793)<br />org.apache.naming.NamingContext.lookup(NamingContext.java:140)<br />org.apache.naming.NamingContext.lookup(NamingContext.java:781)<br />org.apache.naming.NamingContext.lookup(NamingContext.java:153)<br />org.apache.naming.SelectorContext.lookup(SelectorContext.java:137)<br />javax.naming.InitialContext.lookup(InitialContext.java:392)<br />flex.data.DataServiceTransaction.doBegin(DataServiceTransaction.java:836)<br />flex.data.DataServiceTransaction.begin(DataServiceTransaction.java:807)<br />flex.data.DataService.serviceTransactedMessage(DataService.java:705)<br />flex.data.DataService.serviceMessage(DataService.java:429)<br />flex.messaging.MessageBroker.routeMessageToService(MessageBroker.java:1165)<br />flex.messaging.endpoints.AbstractEndpoint.serviceMessage(AbstractEndpoint.java:757)<br />flex.messaging.endpoints.rtmp.AbstractRTMPServer.dispatchMessage(AbstractRTMPServer.jav a:888)<br />flex.messaging.endpoints.rtmp.NIORTMPConnection$RTMPReader.run(NIORTMPConnection.java:4 24)<br />edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Thread PoolExecutor.java:665)<br />edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPool Executor.java:690)<br />java.lang.Thread.run(Thread.java:619)<br /><br />Thanks,<br />Steve
        • 1. Re: Samples - JOTM issue
          seth_hodgson Level 1
          Sorry Steve,
          I don't know whether the JOTM project has active support lists or forums but I'd recommend just testing using a simple JSP page that tries to access the current UserTransaction. Once you get Tomcat and JOTM configured and working properly based on successful execution of your JSP then you'll be good to go, but the JOTM and Tomcat docs are probably your best option.
          Seth
