1 Reply Latest reply on Feb 26, 2008 8:17 AM by (Tom_Jordahl)
    Live Cicle and coldfusion problems?
      Hello, I have one problem with crm example. I have this example and I am working with it, but I have the following problem:
      I have the cfc's files in this directory:
      C:\CFusionMX7\wwwroot\cfcrm\filesDataService
      and I have created one data source in coldfusion to my database.
      so, I defined a coldfusion mappin for my directory that i created in my web root:
      Logical path: /filesDataservice
      Directory Path: C:\CFusionMX7\wwwroot\cfcrm\filesDataService
      I have my proyect in the follow directory:
      Flex directory:
      Live Cycle directory:
      C:\lcds\jrun4\servers\default\flex\cfcrm
      My problem is in the data-management-config.xml. When I write the cfc component:
      in this part
      <component>filesDataService.CompanyAssembler</component>
      what component I need to write?
      I need to define two destination (cfcompany and cfemployee) but I have the following error in the live cycle console:
      [CFDataserviceAdapter] unable to find coldfusion in this server, perhaps you nedd to set <hostname> in the 'cfemployee' destination config?
      thanks for everything
        • 1. Re: Live Cicle and coldfusion problems?
          > [CFDataserviceAdapter] unable to find coldfusion in this server, perhaps <br />> you nedd to set <hostname> in the 'cfemployee' destination config?<br /><br />This is the key, you do not have the integrates CF8/LCDS installation, so <br />you need to configure ColdFusion and LCDS to talk to each other.  It looks <br />like you are running CFMX 7.0.2.  The adapters for CF in LCDS 2.5.1 have <br />been updated to look for the integrated installation by default, which is a <br />change from before.<br /><br />Here is how you get it going.<br /><br />In ColdFusion:<br />  In the CF administrator, you must go to the "Flex Integration" page and <br />ensure you have turned on remote access to CF from LCDS and that the IP <br />address of the LCDS server is listed in the config.  You do NOT need to add <br />any IP address if LCDS and CF are on the same machine as localhost is <br />allowed by default.<br /><br />In LCDS configuration file (data-management.xml):<br />  You must, as the message says, configure a <hostname> field in the <br />destiation.  If CF and LCDS are on the same machine, use "localhost" as the <br />hostname.<br /><br />Hope that helps.<br />--<br />Tom Jordahl
