1 Reply Latest reply on Feb 26, 2008 8:22 AM by (Tom_Jordahl)
    Remote Debugging LiveCycle Trail Version
      Hello,
      I was trying to debug remotely using Eclipse. I uncommented all the batch files in jboss/bin directory to turn on debug options. When I ever I try to connect I get the following message.
      Failed to connect to remote VM. Connection refused.
      Connection refused: connect
      I'm not able to auto-populate the xdp form with xml data when I retrieve the pdf so I was trying to remotely debug the application
      I would appreciate if someone can point if I'm missing something.
      Sameera
        • 1. Re: Remote Debugging LiveCycle Trail Version
          Level 1
          I hope you figured this out already but if you haven't, the JDK for the
          JBoss server is not listening to the same port as Eclipse is trying to
          connect to. Or its not listening at all (your debug switches didn't work).
          Tom Jordahl
