1 Reply Latest reply on Nov 15, 2008 5:19 PM by Newsgroup_User
    Setting Booleans from XML?
    zakel
      I am trying to turn formItem validation "on" or "off " via e4xml. It seems if flex is not allowing me to set "true" or "false" booleans. The loop is correct, I can write "true" or "false" to a alert box. Is it syntax? I am new at this still learning.
      Thanks for any help!
      This is what my flex code looks like:
      var dfformItems3:FormItem = new FormItem;
      dfformItems3.required = x[j].@validate;
      this is my xml node:
      <element position="5." questionlabel="This is a Dual Date Field">
      <item id="5" inputtype="DateField2" validate="false" here="10/12/2009" here2="10/19/2009" tooltip="true" tip="Dual Date Field. If you place your tip over field you should type text into container." ></item>
      </element>
        • 1. Re: Setting Booleans from XML?
          Level 7
          "zakel" <webforumsuser@macromedia.com> wrote in message
          news:gfne9d$f7k$1@forums.macromedia.com...
          >seems if
          > new
          > tip
          > </element>
          The string "true" is not the same as true. Try
          var isRequired:Boolean=x.child(j).attribute('validate')=='true'?true:false;
          dfformItems3.required = isRequired
          HTH;
          Amy
