5 Replies Latest reply on Nov 13, 2008 8:05 AM by atta707
    Have a problem using flex ui with Java application
    gallaharsha
      Hi, I have a built a Flex UI for a java project. The UI has some forms which use a servlet for POST and data populated from servlet. I have used HTTP service to make the calls. I have built my application i.e UI in Flex Builder and when I run my application from flex builder everything works fine i.e data populated correctly..
      But when I open the projects folder and run the html file generated the Http Service does not happen. Can anybody tell me why is this so?? . Moreover I want use this UI for my already existing java project. So what all files (i,e. html, mxml, swf) will be required to be copied to my java project for the UI to work ..
      .Thanks in advance...
