3 Replies Latest reply on Aug 25, 2008 3:44 AM by dylan vr
    PDFGenerator DSC_CONTEXT
    dylan vr
      I'm trying to run PDFGenerator on websphere with LiveCycle ES 8.2
      when I try and call the service I get this error
      ALC-PDG-001-000-Conversion failed because of an exception.
      No Credential or Context set
      Caused by: ALC-DSC-213-000: com.adobe.idp.dsc.DSCException: No Credential or Context set
      I have credentials but no context, what value should I put for the DSC_CONTEXT
        • 1. Re: PDFGenerator DSC_CONTEXT
          Can you provide the details on how you are calling PDFGenerator? When you say "I have credentials but no context...", can you provide the code snippet you are using?
          • 2. Re: PDFGenerator DSC_CONTEXT
            dylan vr Level 1
            Hi Kent
            Thanks for the reply. Here is a code snippet of the constructer which has the properties and below is the method call. The last property is DSC_CONTEXT property which is were I could use your help. I'm using the createPDF2() method because the documentaion said that the createPDF() method was depricated. Thanks again.
            public GeneratePDF()
            Properties ConnectionProps = new Properties();
            ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT_EJB_ENDPOINT, "iiop://localhost:2809");
            ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPORT_PROTOCOL,Service ClientFactoryProperties.DSC_EJB_PROTOCOL);
            ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER_TYPE, ServiceClientFactoryProperties.DSC_WEBSPHERE_SERVER_TYPE);
            ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_USERNAME, "administrator");
            ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_PASSWORD, "password");
            ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_CONTEXT, "");
            * @param docIn Document to be converted
            * @param fileName Name of file to be converted
            * @return Converted PDF
            * @throws ConversionException
            * @throws InvalidParameterException
            * @throws FileFormatNotSupportedException
            * @throws IOException
            public byte[] generatePDF(byte[] docIn, String fileName) throws ConversionException, InvalidParameterException, FileFormatNotSupportedException, IOException
            ServiceClientFactory factory = ServiceClientFactory.createInstance(connectionProps);
            Document inDoc = new Document(docIn);
            String adobePDFSettings = "Standard";
            String securitySettings = "No Security";
            String fileTypeSettings = "Standard";
            CreatePDFResult result = null;
            result = new GeneratePdfServiceClient(factory).createPDF2(inDoc,fileName, fileTypeSettings, adobePDFSettings,securitySettings, null, null);
            // Get the newly created document
            Document createdDocument = result.getCreatedDocument();
            InputStream createdDocumentStream = createdDocument.getInputStream();
            byte [] createdDocumentAsBytes = new byte[createdDocumentStream.available()];
            return createdDocumentAsBytes;
            • 3. Re: PDFGenerator DSC_CONTEXT
              dylan vr Level 1
              Fixed the problem myself. Here is the code.
              This creates the credentials and places it in the context.
              AuthenticationManagerServiceClient authClient = new AuthenticationManagerServiceClient(factory);
              // Authenticate the user
              String username = "administrator";
              String password = "password";
              AuthResult authResult = authClient.authenticate(username, password.getBytes());
              Context context = new Context();
