1 Reply Latest reply on Aug 7, 2009 8:23 AM by Martin Kremers
    Assembler returns null result
      I have a piece of code that uses the AssemblerClient to add a watermark to a document. When I use this piece of code in a normal Java client (not on the LiveCycle server) it works fine. If I copy the piece of code into a webservice (on the LiveCycle server) and call that webservice from a client the same piece of code stops working.
      I'm using some example code from the LiveDocs:
      AssemblerResult jobResult = assemblerClient.invokeDDX(ddx, inputs, assemblerSpec);
      On the client this returs an AssemblerResult that contains the assembler document containing the watermark. The same piece of code in the webservice returns null. Eventhough it returns null I still see the following lines in the server logging:
      2007-12-17 16:59:30,585 INFO [com.adobe.internal.ddxm.Executive] DDXM_N00000: Started processing result named out.pdf
      2007-12-17 16:59:38,959 INFO [com.adobe.internal.ddxm.Executive] DDXM_N00001: Successful assembly of result named out.pdf
      I have absolutely no clue why this fails?
        • 1. Re: Assembler returns null result
          Martin Kremers
          I have the same problem here with livecycle 8.2.1, trying to develop a DSC:
          assemblyDDXDocument and documentMap are just fine! They work also in the process.
          "result" is null in every case! What's wrong here?
          Properties ConnectionProps = new Properties();
                  ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT_EJB_ENDPOINT, "iiop://localhost:2809");
                  ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPORT_PROTOCOL, ServiceClientFactoryProperties.DSC_EJB_PROTOCOL);
                  ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER_TYPE, "WebSphere");
                  ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_USERNAME, "administrator");
                  ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_PASSWORD, "password");
                  AssemblerServiceClient client = new AssemblerServiceClient(ServiceClientFactory.createInstance(ConnectionProps));
                  AssemblerOptionSpec assemblerOptions = new AssemblerOptionSpec();
                  assemblerOptions.setFailOnError(true);
                  assemblerOptions.setValidateOnly(false);
                  assemblerOptions.setLogLevel("FINEST");
                  assert assemblyDDXDocument != null;
                  assert documentMap != null;
                  try {
                      AssemblerResult result = client.invokeDDX(assemblyDDXDocument, documentMap, assemblerOptions);
