3 Replies Latest reply on Sep 24, 2008 8:09 AM by (Alok_Marwaha)
    PDF Generator DOC to PDF Solaris Error
      Greetings, any insight on this error would be helpful! Attached is my environment, code, and stack trace.
      Thanks!
      OS
      SunOS oamsandbox 5.10 Generic_120011-14 sun4u sparc SUNW,Sun-Fire-V440
      Deployments
      Deployment adobe-livecycle-native-weblogic-sparc_sunos (8.2.1,Foundation 8.2.2176.1.183920.1)
      Deployment adobe-livecycle-weblogic (8.2.1,Foundation 8.2.2176.1.183920.1)
      Both are active
      All deployed components active on WebLogic
      Code Being Run
      package com.ccms.poc;
      import java.io.File;
      import java.io.FileInputStream;
      import java.util.Properties;
      import com.adobe.idp.Document;
      import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
      import com.adobe.livecycle.generatepdf.client.CreatePDFResult;
      import com.adobe.livecycle.generatepdf.client.GeneratePdfServiceClient;
      public class GeneratePdf_CreatePDF {
      public static void main(String[] args)
      //Specify connection properties necessary to invoke LiveCycle ES
      Properties ConnectionProps = new Properties();
      //ConnectionProps.setProperty("DSC_DEFAULT_SOAP_ENDPOINT", "http://localhost:7001");
      //ConnectionProps.setProperty("DSC_TRANSPORT_PROTOCOL", "SOAP");
      ConnectionProps.setProperty("DSC_DEFAULT_EJB_ENDPOINT", "t3://localhost:7001");
      ConnectionProps.setProperty("DSC_TRANSPORT_PROTOCOL", "EJB");
      ConnectionProps.setProperty("DSC_SERVER_TYPE", "WebLogic");
      ConnectionProps.setProperty("DSC_CREDENTIAL_USERNAME", "administrator");
      ConnectionProps.setProperty("DSC_CREDENTIAL_PASSWORD", "password");
      // Create a ServiceClientFactory instance
      ServiceClientFactory factory = ServiceClientFactory.createInstance(ConnectionProps);
      System.out.println("-1");
      try{
      //Get a Microsoft Word file document to convert to a PDF document and populate a com.adobe.idp.Document object
      String inputFileName = "/export/home/beauser/docs/adjustment_activity_report.doc";
      FileInputStream fileInputStream = new FileInputStream(inputFileName);
      System.out.println("0");
      Document inDoc = new Document(fileInputStream);
      System.out.println("1");
      String adobePDFSettings = "Standard";
      String securitySettings = "No Security";
      String fileTypeSettings = "Standard";
      CreatePDFResult result = new CreatePDFResult();
      result = new GeneratePdfServiceClient(factory).createPDF(
      inDoc,
      inputFileName,
      fileTypeSettings,
      adobePDFSettings,
      securitySettings,
      null,
      null);
      System.out.println("2");
      //Get the newly created document
      Document createdDocument = result.getCreatedDocument();
      System.out.println("3");
      //Save the file
      createdDocument.copyToFile(new File("/export/home/beauser/pdfs/output.pdf"));
      System.out.println("4");
      catch (Exception e) {
      System.out.println("Error OCCURRED: " + e.getMessage());
      System.out.println("Stack Trace::\n");
      e.printStackTrace();
      ERRORS
      -1
      0
      1
      Error OCCURRED: ALC-PDG-001-000-Conversion failed because of an exception.
      Can't find resource for bundle java.util.PropertyResourceBundle, key 1009
      Stack Trace::
      ALC-PDG-1000-000: com.adobe.livecycle.generatepdf.client.ConversionException: ALC-PDG-001-000-Conversion failed because of an exception.
      Caused by: java.util.MissingResourceException: Can't find resource for bundle java.util.PropertyResourceBundle, key 1009
      at java.util.ResourceBundle.getObject(ResourceBundle.java:325)
      at java.util.ResourceBundle.getString(ResourceBundle.java:285)
      at com.adobe.idp.dsc.util.MessageUtil.formatMessage(MessageUtil.java:252)
      at com.adobe.idp.dsc.util.MessageUtil.get(MessageUtil.java:169)
      at com.adobe.idp.dsc.DSCError.getLocalizedMessage(DSCError.java:304)
      at com.adobe.idp.ds
