2 Replies Latest reply on Oct 9, 2008 4:33 AM by pguerett
    Trying to bind XML data and form fields
      I have a fairly simple PDF - and I am trying to bind XML data to he form fields.
      In the designer I can bring up the data connection and
      select Global - for the binding method - and as I understand it - this will link Form Fields and XML data fields with the same name - (sounds logical to me)
      but all that happens is :
      I see the name of the field in the form field rahter than seeing the actual data
      should I select : None as the binding or normal ....
      but Normal doesnt show Anything - even after i select it .
      I can't quite seem to make this work -
      Any help here would be appreciated
