1 Reply Latest reply on Feb 26, 2009 9:36 PM by (Ullas)
    Render Exception In generating pdf using output service client
      Hi All,
      i am trying to generate pdf using output service client by calling "generatePDFOutput" and passing xdp and data xml parameters as follows,
      but i am facing render exception, any body knows why getting such error.
      try{
      //Set connection properties required to invoke LiveCycle ES
      Properties connectionProps = new Properties();
      connectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT_EJB_ENDPOINT, "t3://localhost:8001");
      connectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPORT_PROTOCOL,"EJB");
      connectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER_TYPE, "WebLogic");
      connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_USERNAME, "administrator");
      connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_PASSWORD, "password");
      //Create a ServiceClientFactory object
      ServiceClientFactory myFactory = ServiceClientFactory.createInstance(connectionProps);
      //Create an OutputClient object
      OutputClient outClient = new OutputClient(myFactory);
      //Reference form data
      FileInputStream fileInputStream = new FileInputStream("C:\\Adobe\\data.xml");
      Document inXMData = new Document (fileInputStream);
      //Set PDF run-time options
      PDFOutputOptionsSpec outputOptions = new PDFOutputOptionsSpec();
      outputOptions.setFileURI("C:\\Adobe\\output.pdf");
      //Set rendering run-time options
      RenderOptionsSpec pdfOptions = new RenderOptionsSpec();
      pdfOptions.setLinearizedPDF(true);
      pdfOptions.setPdfVersion("1.6");
      //Create a PDF document
      OutputResult outputDocument = outClient.generatePDFOutput(
      TransformationFormat.PDF,
      "input.xdp",
      "C:\\Adobe",
      outputOptions,
      pdfOptions,
      inXMData
      //Retrieve the results of the operation
      Document metaData = outputDocument.getStatusDoc();
      File myFile = new File("C:\\Adobe\\Output.xml");
      metaData.copyToFile(myFile);
      catch (Exception ee)
      ee.printStackTrace();
        • 1. Re: Render Exception In generating pdf using output service client
          Hi
          I am also doing a similar activity. and getting a IllegalStateException.
          com.adobe.livecycle.output.exception.OutputException: java.lang.IllegalStateException
          at com.adobe.livecycle.output.client.OutputClient.generatePDFOutput(OutputClient.java:141)
          at CreatePDFDocument.main(CreatePDFDocument.java:56)
          Caused by: java.lang.IllegalStateException
          at com.adobe.idp.dsc.clientsdk.ServiceClientFactory$1.handleThrowable(ServiceClientFactory.j ava:67)
          at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:220)
          at com.adobe.livecycle.output.client.OutputClient.invokeRequest(OutputClient.java:436)
          at com.adobe.livecycle.output.client.OutputClient.generatePDFOutput(OutputClient.java:124)
          ... 1 more
          Caused by: java.lang.NoClassDefFoundError: org/apache/axis/soap/SOAPConstants
          at java.lang.Class.forName0(Native Method)
          at java.lang.Class.forName(Unknown Source)
          at com.adobe.idp.dsc.clientsdk.ServiceClientFactory.createMessageDispatcher(ServiceClientFac tory.java:586)
          at com.adobe.idp.dsc.clientsdk.ServiceClientFactory.getMessageDispatcher(ServiceClientFactor y.java:543)
          at com.adobe.idp.dsc.clientsdk.ServiceClient.getMessageDispatcher(ServiceClient.java:239)
          at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:205)
          ... 3 more
          Please give a solution for this problom.
          regards
          Ullas
