4 Replies Latest reply on Jun 16, 2011 12:34 PM by ibm_lifesci
    Generate PDF : ServicePoolAlreadyExistsException
      I am receiveing a message:
      ALC-DSC-800-000: com.adobe.idp.dsc.pool.service.impl.ServicePoolAlreadyExistsException: Pool for service id GeneratePDFService, major version 1 and minor version 1 already exists
      when trying to convert doc file to pdf using sample code from the site.
      What I have to do to eliminate this problem?
        • 1. Re: Generate PDF : ServicePoolAlreadyExistsException
          AmitB_1977 Adobe Employee
          Sergey,
          Could you please provide the exact LiveCycle version and service pack information?
          Regards,
          Amit Batra
          Engineering Manager,
          Adobe LiveCycle ES
          • 2. Re: Generate PDF : ServicePoolAlreadyExistsException
            Level 1
            Amit,
            I have Adobe LiveCycle ES, version 8.2.1 installed.
            Thanks for answering,
            Sergey.
            • 3. Re: Generate PDF : ServicePoolAlreadyExistsException
              Level 1
              Problem still exists, I cannot avoid it.
              • 4. Re: Generate PDF : ServicePoolAlreadyExistsException
                ibm_lifesci Level 1
                Hi Adobe,
                So what is the cause of this Exception? We see this too in an environment where LiveCycle ES was recently upgraded from LCES 8.2.1 to LCES 8.2.1 SP3.
                [08/06/11 17:44:40:525 BST] 00000039 AWS           W com.adobe.workflow.engine.SynchronousBranch  Method name : handleInvokeAction message is : Pool for service id GeneratePDFService, major version 1 and minor version 1 already exists ALC-DSC-800-000: com.adobe.idp.dsc.pool.service.impl.ServicePoolAlreadyExistsException: Pool for service id GeneratePDFService, major version 1 and minor version 1 already exists
                at com.adobe.idp.dsc.pool.service.impl.ServicePoolManagerImpl.createPool(ServicePoolManagerI mpl.java:141)
                at com.adobe.idp.dsc.pool.service.impl.ServicePoolManagerImpl.getServiceInstance(ServicePool ManagerImpl.java:445)
                at com.adobe.idp.dsc.invocation.impl.PooledInstanceStrategy.getInstance(PooledInstanceStrate gy.java:35)
                at com.adobe.idp.dsc.invocation.impl.InstanceAccessorFactory.getInstanceForInvocation(Instan ceAccessorFactory.java:55)
                at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.allocateInstance(Invocat ionStrategyInterceptor.java:91)
                at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:54)
                at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
                at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
                at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:132)
                at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
                at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:115)
                at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:118)
                at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:91)
                at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:21 5)
                at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:57)
                at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
                at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:730)
                at com.adobe.workflow.engine.SynchronousBranch.handleInvokeAction(SynchronousBranch.java:466 )
                at com.adobe.workflow.engine.SynchronousBranch.execute(SynchronousBranch.java:863)
                at com.adobe.workflow.engine.ProcessEngineBMTBean.continueBranchAtAction(ProcessEngineBMTBea n.java:2773)
                at com.adobe.workflow.engine.ProcessEngineBMTBean.asyncInvokeProcessCommand(ProcessEngineBMT Bean.java:704)
                at com.adobe.workflow.engine.EJSLocalStatelessadobe_ProcessEngineBMTEJB_7d3cbd67.asyncInvoke ProcessCommand(Unknown Source)
                at com.adobe.workflow.engine.ProcessCommandControllerBean.doOnMessage(ProcessCommandControll erBean.java:156)
                at com.adobe.workflow.engine.ProcessCommandControllerBean.onMessage(ProcessCommandController Bean.java:99)
                at com.ibm.ejs.container.MessageEndpointHandler.invokeMdbMethod(MessageEndpointHandler.java: 1014)
                at com.ibm.ejs.container.MessageEndpointHandler.invoke(MessageEndpointHandler.java:747)
                at $Proxy0.onMessage(Unknown Source)
                at com.ibm.ws.sib.api.jmsra.impl.JmsJcaEndpointInvokerImpl.invokeEndpoint(JmsJcaEndpointInvo kerImpl.java:201)
                at com.ibm.ws.sib.ra.inbound.impl.SibRaDispatcher.dispatch(SibRaDispatcher.java:780)
                at com.ibm.ws.sib.ra.inbound.impl.SibRaSingleProcessListener$SibRaWork.run(SibRaSingleProces sListener.java:586)
                at com.ibm.ejs.j2c.work.WorkProxy.run(WorkProxy.java:419)
                at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1497)
