1 Reply Latest reply on Feb 9, 2008 11:40 AM by (WorkflowUser)
    gSOAP invocation question
      We have created a custom service by merging two OOTB services GeneratePDF service and ApplyPolicy services.
      Invoking this custom service via gSOAP web service fails with the following error.
      SOAP 1.1 fault: SOAP-ENV:Server.userException [no subcode]
      "ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error."
      ALC-PDG-011-020-The source file you submitted is not supported by this version of PDF Generator.
      Anyone has any examples of using gSOAP to invoke GeneratePDF service?
      Can post a code snippet if required.
      Praveen Ramamurthy
        • 1. Re: gSOAP invocation question
          Level 1
          looks like you did not specify the fileName parameter for the createPDFG operation, for example if you are converting a Word doc, specify the filename as abc.doc,if converting ppt filename would be abc.ppt(can be anyname as long as there is a the correct extension such as .doc extension)
          If it still does not works after you provide the filename
          mail me the process mergeandfuse@gmail.com
