1 Reply Latest reply on Feb 27, 2008 7:01 AM by Hodmi
    WorkBench
    Level 1
      Just one question
      What if I define the following on my workbench. I have a custom java process(say for extracting zipped XML files), after unzipping the XML files it calls the generatePDF service; will this call behave as a normal function call(because both are deployed as a common process) or will still EJB/SOAP connection needs to be made?
        • 1. Re: WorkBench
          Hodmi Level 4
          I'm a bit unclear as to what you are asking. If you are asking: Can a workflow process that includes a custom component (such as your unzip code) be called via EJB or SOAP as other process are? The answer to that is Yes.
