7 Replies Latest reply on Mar 11, 2008 10:13 PM by (Anthony_Jereley)
    Error when installing a Custom Component
    (Michael_Feichtegger) Level 1
      Hi there,
      I wrote a custom component and built the according jar-file. The next step was to import the jar-file into the workbench.
      When I tried to do so the following error occurred (workbench .log file):
      !ENTRY com.adobe.DSC_Admin_UI 4 4 2008-01-15 16:05:43.418
      !MESSAGE install of C:\tmp\adobe-components\adobe-component.jar failed
      !STACK 0
      ALC-DSC-000-000: com.adobe.idp.dsc.DSCRuntimeException: Internal error.
      Caused by: java.io.FileNotFoundException: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ArchiveStore\306\at\integrata\livecycle\component\Boot strapImpl.class (The system cannot find the path specified)
      The problem is, that the workbench is not running on the same computer as the ES server. When I extract the jar-file manually into the considered directory on the server everything works fine.
      Is this a bug or even not possible to import components from a remote workbench?
      kind regards
      Michael
        • 1. Re: Error when installing a Custom Component
          Level 1
          Hi Michael,
          I ran into the same problem. I created the JAR file in Eclipse Java IDE, then used the 'Install Components' in Workbench. I get the same error you got. Sorry I don't have an answer for you, but I'll keep an eye on this forum and maybe an 'expert' will provide us an answer.
          Good Luck,
          Hope
          • 2. Re: Error when installing a Custom Component
            I got the same issue, i was a packaging problem when you export to your jar file.
            The file tree is important, and have to kept inside the jar, if i remember well
            • 3. Re: Error when installing a Custom Component
              Thanks but I don't think that the tree is wrong because there are just two directories (mainpackage [com.company.component], icons) and the componant.xml in the root directory.
              And as I said, if I'll extrat it manually into the required directory the import works fine.
              Michael
              • 4. Re: Error when installing a Custom Component
                rveldpau
                Hi Michael,
                I think that Debaecker is right. In the error log it actually lists your temp folder. You might wanna double check the structure again. Have you tried opening the JAR with a compression utility like WinRar, or 7-Zip?
                Rob
                • 5. Re: Error when installing a Custom Component
                  Hi Rob,
                  I don't know why, but you have to check the "Add directory entries" checkbox in the JAR Export dialog.
                  The create jar-file looks exactly like the first one I created (checked it with WinZIP and WinRAR).
                  However the new version works very well.
                  Thank you very much.
                  kind regards
                  Michael
                  P.S.: Does anybody know which jar option is hidden behind the checkbox.
                  • 6. Re: Error when installing a Custom Component
                    Ruytero Level 1
                    Hy all,
                    I have been having the same problem.
                    I think the cause with me is that I added libraries my component needs manually into the jar-file of my component and sometimes I added the component.xml file manually into the component-jar. I use 7Zip for this but every I did that I could not get the component to install correctly, unless I unpacked it manually in the temp-dir.
                    I believe this is happens because when I manually place files in the jar file with a tool like 7Zip they are automatically being compressed and the jar-file of a component must not be compressed.
                    So therefore I imported everything correctly in my Eclipse-project and now when I Export my component to a jar-file, everything is included and I don't have to place files manually into the jar-file of my component.
                    When I install a component created like that I don't have any problems.
                    Hope this helps for you to.
                    Regards,
                    RonnyR
                    • 7. Re: Error when installing a Custom Component
                      I got the same error when I was trying to use eclipse to jar up my component.
                      I ended up using the jar task from the command line to build my jar.
                      I made a copy of my component project directory, deleted all the eclipse files (.project etc) and ran the command:
                      jar -0fc jarfilename.jar **
                      (the first parameter is a zero, not an 'oh')
                      from within the top level of the project directory.
                      The jar created this way deployed without any errors
                      Regards
                      Anthony Jereley
                      www.indigopacific.com
