5 Replies Latest reply on Jan 22, 2008 1:21 PM by (WorkflowUser)
    Email Endpoint not naming pdf correcly
    AlvinPearson1
      Hi
      I have a simple process that uses the FormsService renderPDFForm operation. It accepts XML with an embedded tag pointing to a pdf template and produces a PDF file. It all works perfectly when I use a Watched Folder endpoint - I use %F.pdf for the output variable. So if you drop in test1.xml, the output is test1.pdf.
      I then use an email endpoint, and attach an xml file called say test1.xml. Everything works fine and an email is returned with a pdf file attached. The problem is that this pdf file has some arbitrary reference name (not as expected test1.pdf)
      Alvin
