2 Replies Latest reply on Jan 17, 2008 11:07 PM by (Cihan_Aydin)
    Saving XDP form in PDF format at the end of the process
    Level 1
      I want to save my XDP form to a file system as PDF documents at the end of the workflow. There is a service writeDocument to writing PDF files, which accepts 2 parameters as input
      pathname -- type : string
      document -- type : document
      In my workflow , I have an Xfaform variable which holds my form data.
      But, as service requires the parameter as document I could not pass this variable to service. I tried to define a process variable of type document
      and assign my xfaform variable to it, then pass this variable to the service. A pdf file is generated but not valid (1 k).
      My question is how should I pass the variable to this service?
      Thanks in advance
      Regards
      Cihan
