Expand my Community achievements bar.
Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Using process variables in XPath
Avatar
Former Community Member
I am trying to use a variable (/process_data/@Division) to identify an xml node to determine the person for a task:
/process_data/DivisionRolesXML/divisions/division[Division='string(/process_data/@Division)' and Position='Div Executive']/LDAPId
I get no value returned (e.g. result is 'null'). The log shows that @Division has a string value.
It works if the actual value (not variable) is specified:
/process_data/DivisionRolesXML/divisions/division[Division='division_name' and Position='Div Executive']/LDAPId
Thoughts anyone ?
Avatar
This is a sample of the xml data (observed in LC log) being referenced by xpath:
<divisions>
<division>
<Division type="varchar">Brakes</Division>
<Position type="varchar">Div Executive</Position>
<LDAPId type="varchar">swf</LDAPId>
</division>
Avatar
try the following /processData/DivisionRolesXml/divisions/Division
Avatar
Level 9
Hi
I'm reasonably sure that you need to remove the single quotes in your expression. The single quotes mean that your entire sub-clause is being treated as a string, rather than as an expression.
i.e.
...[Division='string(/process_data/@Division)' ...
change to
...[Division=string(/process_data/@Division) ...
Howard
http://www.avoka.com
