2 Replies Latest reply on Jan 25, 2008 8:08 PM by (WorkflowUser)
    How to get the output of a subprocess
    kc@dafolo.dk Level 1
      Hi all,
      I am trying to create a process in which I need to use a gateway with a number of branches. Within each of these branches I need to call a subprocess (in which I have a user assignment) where the user fills in a form. Each of the branches are the same and after the gateway I need to fill an overview form (so to say) with information from each of the branches. Hence I need the xfaform the user filled out inside the subprocess. However when I set this xfaform as "output" from the subprocess I can only see "Output" in the properties of the "invoke" of the subprocess (in each branch). But I can not see any possibility to choose which variable/literal/xpath-expression I want to save this output variable (of the subprocess) into (I mean the output property panel is there but it is empty inside).
      I hope you can understand what I mean - otherwise ask me again and I will elaborate.
      Sincerely
      Kim
