6 Replies Latest reply on Jun 15, 2008 2:06 AM by HowardTreisman
    How to invoke the running process via email or watch folder?
      I initial a process in workspace using a pdf form(xfaFrom type) variable.
      It's a simple process. Just one assign task node to transfer the initial form to process creater.
      The process works fine when submit in workspace.But I have some problem on offline submit.
      I initialed the form on workspace and saved it to local file to edit it.
      After editing the pdf form, how to let the local saved form go back to the process whith the correct data?
      Here is my variable setting in process:
      form type: xfaForm
      render service : render PDF form (in forms sample catagory)
      submit service : Submit PDF Form (in forms sample catagory)
      I've tried to use email endpoint.
      It will be back to the next step of the process, but the data will not be transfer to the form.
      Then I've tried to use watchFolder endpoint.
      And it did not work by some exceptions.
      Failure Time----Tue Mar 18 10:23:52 GMT+08:00 2008
      source location ---- Reason of failure is-----Cannot coerce object: <document state="active" senderVersion="3" persistent="false" senderPersistent="true" passivated="false" senderPassivated="true" deserialized="true" senderHostId="127.0.0.1/192.168.65.143" callbackId="0" senderCallbackId="0" callbackRef="null" isLocalizable="true" isTransactionBound="false" defaultDisposalTimeout="600" disposalTimeout="600" maxInlineSize="65536" defaultMaxInlineSize="65536" inlineSize="0" contentType="application/pdf" length="265731"><cacheId/><localBackendId/><globalBackendId/><senderLocalBackendId/><send erGlobalBackendId><DocumentFileID fileName="C:\Adobe\LiveCycle8\jboss\server\all\svcnative\DocumentStorage\docm120580620223 4\b680381b2f382c4aba702061e12876d6"/><senderGlobalBackendId/><inline/><senderPullServantJn diName>adobe/idp/DocumentPullServant/adobejb_server1</senderPullServantJndiName><attribute s file="C:\Adobe watch folder\offline\stage\Wxebcb14694b8ef1aee4b27261\off.pdf"/></document> of type: com.adobe.idp.Document to type: class com.adobe.idp.taskmanager.form.impl.binarycontent.BinaryContentFormInstance
