4 Replies Latest reply on Mar 20, 2008 8:46 AM by Stephane Gervais
    Can't read the resource
      During creation of pdf form, workbench had a crash.
      Next time I try to reconnect to the LC server to modify pdf form I receive this message:
      "Can't read the resource. Could be due to Invalid permissions, or a
      bad network connection. See the Workbench log for the exact cause."
      Anyone know how to recover from this kind of damage?
      I have to reinstall the client?
      thanks
        • 1. Re: Can't read the resource
          Stephane Gervais
          I think you'll be able to find the real cause of the error in the Workbench log at WORKBENCH_HOME/Workbench/workspace/.metadata/.log
          Let us know what you find.
          Cheers.
          • 2. Re: Can't read the resource
            Level 1
            This is the log report, I can't understain which is the matter
            !ENTRY com.adobe.repository.ui.eclipse.forms 4 0 2008-03-20 12:53:51.659
            !MESSAGE REP-003-020: Problem opening resource for viewing
            !STACK 0
            java.lang.NullPointerException
            at com.adobe.repository.ui.eclipse.core.RepositoryItem.openForView(RepositoryItem.java:708)
            at com.adobe.repository.ui.eclipse.actions.OpenViewerAction.doAction(OpenViewerAction.java:8 9)
            at com.adobe.repository.ui.eclipse.actions.TreeViewerAction.run(TreeViewerAction.java:105)
            at com.adobe.repository.ui.eclipse.views.RepositoryView$2$1.run(RepositoryView.java:661)
            at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1737)
            at com.adobe.repository.ui.eclipse.views.RepositoryView$2.doubleClick(RepositoryView.java:66 6)
            at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:796)
            at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
            at org.eclipse.core.runtime.Platform.run(Platform.java:843)
            at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
            at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:149)
            at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:794)
            at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1 227)
            at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java: 1158)
            at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:223)
            at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:220)
            at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:281)
            at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
            at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
            at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3348)
            at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2968)
            at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1914)
            at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
            at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:419)
            at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
            at com.adobe.lcide.rcp.Application.run(Unknown Source)
            at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
            at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:92)
            at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:68)
            at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
            at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
            at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
            at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
            at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
            at java.lang.reflect.Method.invoke(Unknown Source)
            at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
            at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
            at org.eclipse.core.launcher.Main.run(Main.java:977)
            at org.eclipse.core.launcher.Main.main(Main.java:952)
            • 3. Re: Can't read the resource
              Level 1
              I tried to remove the previous connection to the LiveCycle server and recreate a new one with different name.
              Using this new connection now I can connect to the resources.
              I think this is a Livecycle bug!
              • 4. Re: Can't read the resource
                Stephane Gervais Level 1
                Yes, please report the incident (and your resolution) to support.
                Thanks.
