Expand my Community achievements bar.
Deserializer ..encountered child element which is NOT expected
Avatar
Level 3
Hello I created a process in Workbench that accept input documents (PDF and <br />MSWord) and uses the Assemble and Generate PDF service to merge the inputs into a single PDF. However, I am getting a fault exception <br />soapenv:Server.userException.<br />currently I'm trying to get it to work with one single input of a word document. <br /><br />Thank you for any insight to what might be causing the deserialization exception. <br /><br />HTTP/1.1 500 Internal Server Error<br />Server: Apache-Coyote/1.1<br />X-Powered-By: Servlet 2.4; JBoss-4.0.3SP1 (build: CVSTag=JBoss_4_0_3_SP1 date=200510231054)/Tomcat-5.5<br />Content-Type: text/xml;charset=utf-8<br />Transfer-Encoding: chunked<br />Date: Tue, 29 Apr 2008 21:04:46 GMT<br />Connection: close<br /><br />376<br /><?xml version="1.0" encoding="utf-8"?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Server.userException</faultcode><faultstring>org.xml.sax.SAXException: SimpleDeserializer encountered a child element, which is NOT expected, in something it was trying to deserialize.</faultstring><detail><faultData><ns1:exception xsi:nil="true" xmlns:ns1="http://adobe.com/idp/services"/><ns2:message xmlns:ns2="http://adobe.com/idp/services">SimpleDeserializer encountered a child element, which is NOT expected, in something it was trying to deserialize.</ns2:message></faultData><ns3:hostname xmlns:ns3="http://xml.apache.org/axis/">DCAN00429351A</ns3:hostname></detail></soapenv:Fault></soapenv:Body></soapenv:Envelope><br />0<br />AND I don't see a problem on the input<br /><br />top of input:<br /><br />POST /soap/services/docb3_assm?blob=base64 HTTP/1.1<br />content-type: text/xml; charset=utf-8<br />content-length: 49112<br />soapaction: "invoke"<br />accept: text/xml<br />sap-srt_id: 20080429/230444/v1.00_final_6.40/CFD014483801E93FE10000000A424026<br />user-agent: SAP Web Application Server (1.0;700)<br />host: 10.7.104.129:8090<br />accept-encoding: gzip<br />authorization: Basic YWRtaW5pc3RyYXRvcjpwYXNzd29yZA==<br />sap-language: E<br /><br /><soap-env:Envelope xmlns:soap-env="http://schemas.xmlsoap.org/soap/envelope/"><soap-env:Header><n0:Trace xmlns:n0="http://www.sap.com/webas/630/soap/features/runtime/tracing/"><TraceLevel xmlns="http://www.sap.com/webas/630/soap/features/runtime/tracing/">Error</TraceLevel></n0:Trace></soap-env:Header><soap-env:Body><nr1:invoke xmlns:nr1="http://adobe.com/idp/services" xmlns:nr2="http://xml.apache.org/xml-soap"><nr1:mapOfDocuments><nr2:item><nr2:key>item000.doc</nr2:key><nr2:value><nr1:contentType>doc</nr1:contentType><nr1:binaryData>PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0idXRmLTgiPz4KPHc6d29yZERvY3VtZW50IHht<br />bG5zOmR0PSJ1dWlkOkMyRjQxMDEwLTY1QjMtMTFkMS1BMjlGLTAwQUEwMEMxNDg4MiIgeG1sbnM6<br />bz0idXJuOnNjaGVtYXMtbWljcm9zb2Z0LWNvbTpvZmZpY2U6b2ZmaWNlIiB4bWxuczp3PSJodHRw<br />Oi8vc2NoZW1hcy5taWNyb3NvZnQuY29tL29mZmljZS93b3JkLzIwMDMvd29yZG1sIiB4bWxuczp3<br /><br />BOTTOM OF INPUT:<br /><br />VydmUiPiA8L3c6dD48L3c6cj48L3c6cD48L3c6<br />ZnRyPjx3OnBnU3ogdzpoPSIxNTg0MCIgdzp3PSIxMjI0MCIvPjx3OnBnTWFyIHc6Ym90dG9tPSIx<br />NDQwIiB3OmZvb3Rlcj0iNzIwIiB3Omd1dHRlcj0iMCIgdzpoZWFkZXI9IjcyMCIgdzpsZWZ0PSIx<br />ODAwIiB3OnJpZ2h0PSIxODAwIiB3OnRvcD0iMTQ0MCIvPjx3OmNvbHMgdzpzcGFjZT0iNzIwIi8+<br />PHc6ZG9jR3JpZCB3OmxpbmUtcGl0Y2g9IjM2MCIvPjwvdzpzZWN0UHI+PC93eDpzZWN0Pjwvdzpi<br />b2R5Pjwvdzp3b3JkRG9jdW1lbnQ+</nr1:binaryData><nr1:attachmentID>dummy</nr1:attachmentID><nr1:remoteURL>dummy</nr1:remoteURL></nr2:value></nr2:item></nr1:mapOfDocuments></nr1:invoke></soap-env:Body></soap-env:Envelope><br /><br />Thank you for any insight to what might be causing the deserialization exception. <br /><br />Regards, Jesse
Avatar
Level 9
Hi Jesse
How are you invoking the process? WatchFolder, invoking it from Java, or something different?
Howard
http://www.avoka.com
Avatar
Level 1
Hi -
I'm also having same issue with LiveCycel ES PDFGenerator. I'm invoking PDFG with web service using BLOB over https. PDFG is running on JBoss.
I generated client stubs for async process using the URL mentioned in documention.
Anand
